tire traction?
/ tire traction? #21
Builder said:
Because i needed to respond to this:
"My 5525 (4wd or 2wd) with R1s will always outpull my 4720 with R4s'"
Yeah, but his full post presented better balance than the excerpt. Its easy to get a bsfilter flareup on an isolated statement.;)
larry
/ tire traction? #22
1. Get the 4x4. (IMHO this is always a good choice)
2. Get tires with a tread for the most damage-sensitive situation you generally need. For example, if you mostly just cut your lawn, get turfs. If its mostly backhoe, loose/dry dirt moving, or running on pavement, get R4's. If the tractor is to be almost always used off-road in the woods, field, dirt, or snow, get R1's.
3. If you need more traction in mud or other sloppy conditions on an occasional basis, temporarily add some aggressive tire chains. Chains are a lot cheaper and easier to swap-on than an extra set of tires and a whole lot cheaper than a entire extra tractor.
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
(2) Hakkapelitta 360/80R28 Tires & Rims (A64911)
(2) Hakkapelitta...
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A67714)
2013 FREIGHTLINER...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
