Tire substitution question
/ Tire substitution question #1
kude
I am looking at replacing the rear tires on a 755, factory turf tire size 31x12.50-15. The closest size I can find is 31x13.50-15. Is this aqcceptable or is there a problem. I am assuming the tire is 1 inch wider, but diameter and rim diameter is the same.
/ Tire substitution question #2
Is the tractor 4x4 or have a mid mount mower?? If it is either of these I would not change tire size.
The MMM has been removed and most likely will be junked. Yes, it is 4x4 ehydro.
/ Tire substitution question #4
Only the very early model 755 2WD came with 31x12.50-15 inch tires. All later models, 2WD and 4WD, came with 33x12.50-15. 31 inch tires are not for use with 4WD. This can be confirmed on JD Parts.
Thanks, I was going by the manual, I found a source for the proper size.
ARIZONA DRIP SYSTEMS-SUNDANCE TAPE INJECTOR (A64280)
ARIZONA DRIP...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2019 CAT 259D (A60462)
