Tire sizes
/ Tire sizes #1
JD 1250
Milton, Tn
John Deere 1250
I have a John Deere 1250 that has 14.9-28 tires on it. My question is, can I put 16.9-28 tires on the same rims that the 14.9-28 tires are on? Thanks for your help.
/ Tire sizes #2
You might be able to put them on, But they probably would not have full tread connect.
14.9 should be on a 12 or 13 inch wide wheel. I am guessing you 12 inch wide wheels.
16.9 should be on a 15 or 14 inch wheel. 15 inch wide prefered
/ Tire sizes #3
Also if you have mfwd, the 16.9s will be taller and throw off your front to rear tire ratio.
/ Tire sizes #4
FWIW - My Kubota M6040 runs R-1 Firestone on the rear. They are 16.9 x 28 - - mounted on Titan 28 x 15 steel rims.
For sure - if your tractor is MFWD(4 WD) - then going from 14.9-28 to 16.9-28 WILL create problems with the MFWD system.
JOHN DEERE 6 CYL DSL POWER UNIT (A63291)
JOHN DEERE 6 CYL...
John Deere 7230 (A62180)
John Deere 7230...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2022 EZ-GO ELITE...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
