Tire Size comparison
/ Tire Size comparison #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I am looking at some 100hp tractors give or take a few HP. Tire options for the rear are 18.4R30. 143A8R1
or 420 85R34 147A8R1w. What are the advantages and disadvantages of each?
/ Tire Size comparison #2
18.4 30 are cheaper and i think more common .
/ Tire Size comparison #3
I agree. At least around here. Most of the big machines up here have 16.9-38s on them.
Yes I agree they are cheaper and more common. Does the other size have any advantages?
/ Tire Size comparison #5
You didn't state what tractor they are going on. That does make a difference, some things that count to the tire size. Two or four wheel drive, the tractor weight, and the use. To me the 18.4 30 is the most common size but most commonly used on 70 horsepower tractors! That would mean to fully utilize them you would need more weight to get traction or you would be spinning a lot. 34" or 38" are the most commonly used tires when you get to 100 horsepower four wheel drives. Two wheel drives we might option to 42" to balance the traction although if it is loader equipped we might go back to the 38" to still leave power with the additional rear ballast needed to offset the loader.
They would go on a 115hp JD, a 5115M.
/ Tire Size comparison #7
Yes they are definitely more common but cheaper is only relative there is nothing cheap about any of these tires, i was curious how much a titan radial 18.4-30 was for my m8540. if i remember correctly list price was well north of $2k each. Decided i really hoped i never scraped a tire. A guy at work was complaining about the cost of tires for his vette i told him 1 tire on my tractor cost more than as all 4 of his.
Dave
/ Tire Size comparison #8
can you get 18.4x38s on it?
/ Tire Size comparison #9
i would be looking at a 34r or a 38r for that tractor i kubota has them two choice for 70 to 95 horse over 100hp 38 s if you can get 34 s go foe it but be aware of the wieght rating of the tire ask what the rating is on each tire choice i know my 30x16.9 on my 70 hp kubota are rating lower them the tires on my 3500hd srw truck
/ Tire Size comparison #10
The 420/85R4's are R1W's so they are 50% deeper tread than the 18.4R30's and also I have experience with those 18.4R30s on a 5085M and they are not as good as the 420/85R34's
I have a pair of 480/85R38s Firestone's on my 6715 and they only have worn 5%-8% in 1400 hours. It has seen roads almost every day in the spring to fall. Guessing about 10 miles a day with employees driving it.
18.4R30 Goodyears on a 5085M about 400 hours, wore about 5%-10% Seen probably less road but still wears down quickly.
With the deeper thread you'll get more traction and better wear. Since your getting more tire.
The 420/85R34's are just 16.9R34's
/ Tire Size comparison #11
MY JD 6415 (85hp) came with 18.4R-34s I was surprised it had such big tires for an open station tractor.
I don't think so. I just pulled the trigger on a 6330 in stead of the 5115 and it as the 34's on it.
/ Tire Size comparison #13
The 420/85R34 has an English equivalent 16.9R34, is 16.5 inches wide, and has a 188 inch rolling circumference. Tread depth is 56/32 inches. Titan list price is $3007.49. The advantages are higher load capacity, greater floatation, improved traction and smoother ride.
The 18.4R30 is 19.3 inches wide and has a 182 inch rolling circumference. Its tread depth is 50/32 inches. Titan list price is $1755.49. The advantages are tread wear and durability, maximum tread cleaning and sidehill slip resistance.
The advantages are the ones listed in the Titan book for those particular sizes.
From the John Deere sales manual, the R1W tires offer a deeper tread and are popular in wetter soils. It goes on to say that many European utility tractors use R1W tires. But 56/32 vs 50/32 doesn't seem like that much tread height difference (only 3/16 inch) but the tread patterns shown in the Titan book are very different.
Finding the right tires
Thanks a ton!
JOHN DEERE QT LOADER LINKADGE (A63290)
JOHN DEERE QT...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
BRANDT 5000EX GRAIN VAC (A63290)
BRANDT 5000EX...
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
JOHN BLUE 300 GALLON NITROGEN APPLICATOR (A63290)
JOHN BLUE 300...
