Tire size advice needed
/ Tire size advice needed #1
hondo964
JD 950 JD 5055e
I was looking at a JD 5225 and it had rear ag tires that are 13.6-28 on a 12 inch rim. They were shorter and considerably narrower than a tractor that was 10 Hp larger (JD 5303). These were 16.9-28. I was surprised to see that difference.
Can anyone help me understand what the implications of these Shorter and Narrower tires would be in operating the tractor?
/ Tire size advice needed #2
Not sure what information specifically you are looking for, but in my opinion you see the larger wider tires standard on the higher horsepower tractors in most line ups. I have 14.9-28 tires on my 2WD 5105 and have driven a neighbors 2WD 5205 with 16.9-28 tires and the 16.9 tires seem to substantially improve the traction. These two tractors are the same size and set up the same. The 5205 has a few more horsepower, I think 6 at the motor and 4 at the PTO. The other side too is that the larger tire holds more fluid for ballast which also helps. I personally would go with the biggest tire I could for my needs and use.
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2011 Mercedes-Benz C300 AWD Sedan (A66738)
2011 Mercedes-Benz...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
