Tires Tire Sealant ???
/ Tire Sealant ??? #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
Has any one used "Multi-Seal" http://www.multi-seal.com/ as a preventitive against flat tires.
Any other recommended products , I have 2- 16.9 x 28 and 2- 9.5-16 Ag's to treat so I would think approx. 5 Gallon pail should do the job. Also need a Delivery system to get it in the tires.
Thanks.
/ Tire Sealant ??? #2
Slime has done a great job for me. It looks like Multi-Seal is probably even better.
/ Tire Sealant ??? #3
Thanks.
Our property is full of thorns. Used to get flats on my last rig all the freggin time. I installed Multi-Seal on the TC40D two years ago when it was new and haven't had a flat since. I still get the thorns in the tires but now it doesn't matter. Muti-Seal isn't cheap but after helping my neighbor dismount and remount two rear filled tires on his old Massey the alternative is much easier on the back. I purchased 5 gallons on-line.
/ Tire Sealant ???
I have been on Multi seal Web site , but they dont have an online store. I call the toll free number 2 days ago, they took my number and said they would check to see if they had a retail seller in my area. They do not sell direct, unless you are a Business / Fleet .
2 years ago is a while, but by chance do you remember the site you bought it from, and Approx. cost ?
Did you buy thier pump?
Thanks
/ Tire Sealant ??? #5
Thanks
Since I'm in Ohio I used these guys Multi-Seal I'm sure they would ship anywhere in the USA though.
I do own one of the metal pumps and you are more than welcome to use it if:
You pay the shipping charges to and from. I can even enclose a UPS tag for the return trip and arrange a pick-up at your home if you like (UPS loves us). And I ask that the pump be cleaned after it's use.
If interested send me a PM and we'll work out details.
/ Tire Sealant ???
Pineridge,
Thanks for offering the Pump , I will PM you once I recieve the Multi-seal, to work out the details on getting the Pump. The company I work for ships by UPS daily.
I just ordered a 5 gallon pail, they said please allow 3 weeks for delivery.
/ Tire Sealant ???
Mike,
I just sent you a PM . I forgot to ask the dimension and weight of the box.
Thanks Again,
Dan
/ Tire Sealant ??? #9
7 pounds weight
The box is 23 X 12 X 4 inches
It will be going out in todays UPS shipment.
/ Tire Sealant ???
Mike,
Thanks again, will expect it next week, depending on the UPS schedule with the Fourth of July.
I should be going back to the Country place the Weekend of July 8th, I will put Sealant in tires then , and will get info for shipping back the week of the 10th.
Dan
/ Tire Sealant ???
Mike,
I used the Pump this weekend worked great. I took the Valve Core out , jacked the Tractor up, lowered pressure to 5 PSI, noticed that the AGs looked like they may relax and come off the rim. So I kept a little pressure in the tire. On the 24 1/2 pump, the pump stopped. I thought great something just happened to the BORROWED pump, so I pulled up to get a full stroke and pushed again, nothing it didn't budge. Pulled the fitting of the Valve Stem """SPLAT""" Multi-Seal all up my arm, chest, neck. From that little pressure that I had put on the Fill hose once it clogged, it was a jet of Multi-seal out of the hose, against the Rim and right back at me. This was on the Back Tire, So I removed the valve stem that threads into the larger Stem. Air starts flowing, look in the stem. Multi-Seal did what it claims ( Seals large punctures and holes) A small piece of the Black ground up rubber had lodged in the Stem then the fine fibers had filled in around that.
After clearing the Stem, I looked back at the Tire , It had relaxed off the Rim, GREAT, pulled out the Air Compressor gave it a shot of air NOTHING , just a hissing as the air came out as quick as it went in.
By now the Tractor and Tire that was in the Shade an hour ago when I started the process is now starting to get a little of a Sun Tan. So I grabbed the Ratchet strap and tried "Spreading" the tire to get it back tight against the Rim. 30 minutes later , still hissing. It is HOTTT about now, so head to the house, grab lunch and refreshments. AC feels really good, maybe the Tire setting in the sun for and hour or so will do it some good, "Make it more flexible " , so after an Hour and a Half nap, back out there . Still no Luck.
Read all warnings and make sure Multi-Seal is not Flammable. I revert to the Ether method, Quick Spray around the Rim, one match later, "WHOOF, POP" and the Tire is Set , put valve core in and air tire up.
Job Done.
/ Tire Sealant ??? #12
Good story, glad everything finally came together for you. My Multi-Seal went in without a hitch, does that mean I'm blessed? Come to think about it whenever I do something stupid around here my wife does say god bless it! :D
/ Tire Sealant ???
Mike,
Check your PM, I want to verify the Return Address, for the Pump. It is Clean and oiled with 30 Weight. I did not have any Synthetic so I hope Conventional Dino oil is OK.
Thanks for the Use of the Pump, Let me know if there is anything I could do to return the Favor. Will be glad to.
Dan
/ Tire Sealant ??? #14
Hey Deer hunter.Glad you got it fixed. Could you describe the either mounting procedure abit more. I saw it on TV once on a Tundra Bus . But Didn't think it was something Id want to try without some info.
Is there just one flash of flames? and how long a time do you have once you start the spray around the rim?
Al
/ Tire Sealant ???
Al
The Smaller the tire the more exacting you have to be with the amount of Ether. But for the most part if the tire is small then you can usaully set the bead using a normal Air Compressor.
Ether is used as a last resort, you CAN BLOW:eek: :eek: up a tire if you use too much.
Remove Valve Core. I try to get one side of the tire set / Pressed on the Rim, press the other side away from the Rim, Then Spray aprox 1/2 to 3/4 around rim up into Tire Carcass, a little spray on the side of tire and a trail about 6 feet from the tire. Another person there with a Lighter or Match, the minute you get through spraying , they light the trail.
You should hear a whoof and Snap/pop , (the tire setting against the rim). Have air hose ready , immeidiatley after tire has set on rim, you must start pumping air in. If it is a Large tire and you have sprayed more ether than needed the ether will continue burning the Oxygen from inside the Tire. Reversing what you just accomplished, It Will SUCK the tire back off the rim. Air hose and pumping air fast will keep this from happening.
Ether is the LAST RESORT, it is NOT safe , and may catch things on fire.
/ Tire Sealant ??? #16
And, it can cause flies to fall asleep :D
Bob
/ Tire Sealant ??? #17
Thanks. and I understand the disclaimer.I am lucky I haven't had to use that method. I have an inflatable bead sealer. But it wouldn't work for a tractor tire. But then I use tubes so its never been a problem.
Thanks for the explanation I did a search and found almost exactly what you described. but they only went 5 feet. not six.I guess they were a little bit more cheap with the either. LOL
Safety first.
Allan
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
(2) 480/70R28 TIRES W/ 8 LUG RIMS (A64280)
(2) 480/70R28...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
Caterpillar 615C Scraper Service and Parts Manuals (A63117)
Caterpillar 615C...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2018 International LT Automatic Day Cab (A62613)
2018 International...
