tire rims
   / tire rims #12
I have an Iseki TA207. I had Hey Machinery make a set of wide rims for it. I put industrial tires on them. He can take rims and make centers to any bolt pattern and offset you want. They aren't cheap, but they are very heavy duty.
785-594-3441
   / tire rims #13
Yes, it seems that a lot of the small diesel tractor rims can be interchanged. I don't know all the models that can cross, but there are some.
   / tire rims #14
I found the picture where it looks like they put trailer rims on the front of the tractor.
   / tire rims #15
The Hoye tractor site got back to me and they said they also can make any bolt pattern I want. They seem to be another good source. Now I just need to confirm what bolt pattern I have on my Bolens G154 (Iseki TX2140F). These are hard to measure but I think they are:
Where d=bolt hole diameter, D=large hub opening diameter, I=diameter of circle bolt holes fall on.
Front D=70mm. I=100mm d=13mm. 4 bolt
Rear D=90mm I=120mm d=13mm. 6 bolt
   / tire rims #17
I learned a hard lesson this week. I had my front tires loaded, I don't have an FEL, and I use a dirt scoop, so I need at the weight I can get on the front. I used my impact wrench, on my original OEM rims, that came on the tractors, and I cracked them all the way around the bolts. I brought it to have it welded, and they looked at it, and said that it was not worth the money, and would be difficult to weld. I searched very hard for a new rim,a nd the only one I could come up with is one from Yenebiz, and the shipping anlone is over $200 from Europe. I did alot more research, and finally I found that the rime from a Kubota B7100, B6100, B5100 will fit perfectly, and the rims runs around $100. I had the dealer measure it, and it is a perfect match, and it even has the wheel weight holes that match up the same. I think that the rims are made by the same company in Japan for both Iseki and Kubota. I just need to paint it white when it gets here, and have the tire remounted. The part number for the tire is, 70000-00024. This site has it for $115, but I ordered it from a dealer because I wanted it to match exactly, and this rim has gaps on the inside. Anyways, i thought that you guys may be interested who have been looking for front rims. This is for the 5.00 by 12 rim size.
Kubota 5X12 Front Wheel
Mitch
   / tire rims #18
Thanks for the link. Those rims are very difficult to find. I thought I found some for $70/ea (from one of the threads here - maybe even this one). When I got the two I ordered I opened the box and everything appeared like they were the ones I needed (4 bolt holes, 5-12, etc.) After closer inspection they are for a TS1910 or something like that so all the hole patterns are too large but it wasn't obviously different from initial inspection. Kind of a bummer. I decided not to send them back but instead I'm hoping modify them some day with the help of a lathe and some welding/recutting. I think it can be done but that will be down the road sometime.
Don't throw away your old rims. I'd pay you shipping + something for your time if you're going to do that.
   / tire rims #19
I also have a G152 and have looked for rear tires and found none, also the last time I tried to call Sam's bolens, last month the phone numbers were both out of order.
   / tire rims #20
My new front rim came in today for my Bolens G154. It is a Kubota 70000-00024, and it is a perfect match. I think that it is the exact same rim as the OEM rim. Perfect fit. You can see the self inflicted damage I did to my old rim by over tightening the bolts with an impact wrench. Costly mistake. The rim was about $120.00 plus shipping to give you an idea. I wanted an OEM rim, but this is the same thing, just orange. Now to paint it white, and have it reloaded and mounted. Otherwise the tractor would look like a Bobcat tractor. Not that this would be a bad thing, I like their tractors, but its a Bolens, so, anyways, I thought you guys who were looking for rims might be interested.
Mitch
. T/A TRASH TRAILER (A58216)
. T/A TRASH...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
HOOPER 101" X 20' GOOSENK TRAILER (A52708)
HOOPER 101" X 20'...
2017 Komatsu WA500-8 Articulating Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo (A59076)
2017 Komatsu...
JOHN DEERE GRILL GUARD FOR 5000 SERIES TRACTOR (A52708)
JOHN DEERE GRILL...
