Tires tire question
/ tire question #1
klint
does anone know if i can change the wheels inside out on 855 with ag tires?i want to do this for a wider stance.and does anyone know if a loader from a 655 and 755 will fit on a 855?
/ tire question #2
I had a couple of 750's and they are pretty similar to the 850. I think on the 855 you can swap the wheels for a wider/narrower stance, depending on which way it's set up now. But, you don't turn the rims "inside out", just swap the leftside with the rightside and vice-versa so the directional tread will still be pointed in the same direction. Not sure about the loaders.....
/ tire question
thats what i meant.does anyone know if you can put turf tires on these rims?
/ tire question
i talked to the dealer and you can swap them.and i guess there are other ways to widen the stansce to.i need to get the manual.
/ tire question #5
I believe that the rims for the turfs are wider than the rims for the ag's. I think they are a different diameter as well. You can check that with your dealer as well to be sure.
/ tire question #6
Not sure what wheels and rims you have but some of the older types allowed you to turn the centers around and bolt up in multiple widths tracks. The newer wheels are cheaper and don't have as many features.
I would be suprised if you can mount turf tires on ag wheels though since the real turf tires have a much larger cross section. You may also look into R4 tires which have good traction and are less likely to tear up your grass than the ag tires.
All depends on what you are trying to achieve.
Steve
/ tire question #7
klint, by any chance you're not in the Southeast area are you?
/ tire question
no im in michagan.i would love to get r4 tires but there $$$$$.i will use these until they fall apart.or until i cant stand them anymore.
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
