Tire puncture
/ Tire puncture #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Hello, I noticed a drywall screw stuck in the thread pattern on the rear industrial tire of the 2816. I pulled it out and sure enough its leaking. What have most used to seal the tire...plugs? or some of the spray patch?
/ Tire puncture
I'd have to find out, but I believe its tubless. I have no ballast in them, though I was going to put some in it..it needs it. I guess a plug it is, ..its right in the thread pattern...a good 1.25 to 1.5 inches deep. Why did you ask about the ballast?
/ Tire puncture #5
I was concerned about any possible pets you had. If you had regular antifreeze - water mix ballast - it would kill them. Also, if this were the case, suggesting that you position your tractor so the valve stem would be at 12 o'clock. Best wishes.
/ Tire puncture
Ahh, No pets at the moment. Good thought though. I hope the plug holds....
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
Ford F800 (A63689)
Ford F800 (A63689)
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
karcher pressure washer (A61567)
karcher pressure...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
