Tire puncture
/ Tire puncture #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Hello, I noticed a drywall screw stuck in the thread pattern on the rear industrial tire of the 2816. I pulled it out and sure enough its leaking. What have most used to seal the tire...plugs? or some of the spray patch?
/ Tire puncture
I'd have to find out, but I believe its tubless. I have no ballast in them, though I was going to put some in it..it needs it. I guess a plug it is, ..its right in the thread pattern...a good 1.25 to 1.5 inches deep. Why did you ask about the ballast?
/ Tire puncture #5
I was concerned about any possible pets you had. If you had regular antifreeze - water mix ballast - it would kill them. Also, if this were the case, suggesting that you position your tractor so the valve stem would be at 12 o'clock. Best wishes.
/ Tire puncture
Ahh, No pets at the moment. Good thought though. I hope the plug holds....
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
MASSAGE CHAIR (A58214)
Willmar 4550 Wrangler Articulating Loader (A61307)
Willmar 4550...
