Tire puncture
/ Tire puncture #1
VroomVroom
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Hello, I noticed a drywall screw stuck in the thread pattern on the rear industrial tire of the 2816. I pulled it out and sure enough its leaking. What have most used to seal the tire...plugs? or some of the spray patch?
/ Tire puncture
I'd have to find out, but I believe its tubless. I have no ballast in them, though I was going to put some in it..it needs it. I guess a plug it is, ..its right in the thread pattern...a good 1.25 to 1.5 inches deep. Why did you ask about the ballast?
/ Tire puncture #5
I was concerned about any possible pets you had. If you had regular antifreeze - water mix ballast - it would kill them. Also, if this were the case, suggesting that you position your tractor so the valve stem would be at 12 o'clock. Best wishes.
/ Tire puncture
Ahh, No pets at the moment. Good thought though. I hope the plug holds....
LEEBOY 8510C ASPHALT PAVER (A64279)
LEEBOY 8510C...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2016 Clemett Tri Axle End Dump Trailer (A64047)
2016 Clemett Tri...
2000 FREIGHTLINER 3-AXLE BOBTAIL VACUUM TRUCK(INOPERABLE) (A63569)
2000 FREIGHTLINER...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
