Tire Prices!! Geeze
/ Tire Prices!! Geeze #21
Good to know. I am looking at the Falken MT tires.
I have had 2 sets of Falken Tires on both of my Saturns and really had good service out of them.
Chris
I had a set of Falkan on my 2006 Buick and got only 19000 miles on them. I replaced them with Bridgestones (almost twice the price),but with over 10000 miles on them I see almost no wear.:thumbsup:
/ Tire Prices!! Geeze #22
usually get my tires from tread depot.com. Had to buy a trailer tire for my dual axle trailer. local tire shop sold it to my for 85.00 out the door. on line it was 80.00
/ Tire Prices!! Geeze #23
You guys are depressing me, I've got to get new tires (6 of them) for my DRW Dodge 3500 utility body. I'm afraid to ask what they will cost.
The stock American generals only lasted 25,000 miles :mad:
They have to be as HD as they make for that size, since the truck sits at ~ 12,000 pounds.
Just bought 2 batteries, CTD, for $250. :(
JB
/ Tire Prices!! Geeze #24
JB
Just 2 new batts. 200.00. for mine. They give me a discount at the parts store
I put toyos on mine 285-75-17 last yr I believe I paid like 800.00 from tread depot
/ Tire Prices!! Geeze #25
They get rotated every 7,500 miles.
My Suburbans seem to wear tires fairly evenly. Is there any advantage to rotating them, given this? I have never taken the time to do it. I guess my spare is probably rotting away.
When I commuted to work I had a FWD sedan, and that car used front tires faster than rear ones as expected. When I only needed one pair at a time I would put the new ones on the rear like they recommend. I just don't understand the value of rotating your tires all the time unless they wear the outsides faster than the insides or whatever, but my vehicles haven't that I've noticed.
/ Tire Prices!! Geeze #26
I guess you don't tow much. Most AT truck tires have about 13/32" tread when new. I have measured all my tread depths then towed 2000 miles and measured again and have seen the rears lose 3/32"
I also like to buy all 4 tires new at the same time, not just 2. If I rotate I can get even wear all around. Does not matter if its a little fwd car or my F350
Chris
/ Tire Prices!! Geeze #27
I just re shod my Lesabre...
Got lucky in that they were 15" tires...
Got the whole set for $85 ea with 65K tread wear rating...
These newer cars and truck utilize the larger sizes and they sure are pretty but very expensive to keep up...
/ Tire Prices!! Geeze #28
Whew, you guys make me glad I don't have any of those modern 17" and bigger tires.:laughing: I bought a new set of 4 BFG Long Trail T/A P225/70R15 tires for my old Ranger from Discount Tire on 10/4/07 for a total out the door price of $426.55. They rotate them ever 7k miles and re-balance every 2nd rotation or upon request, repair flats, etc. at no cost. They're supposed to be 60k mile tires and I reckon that's right since they don't appear to be half worn out with 28.4k miles. I just looked at Discount Tire's website and those tires are now $125 each, but that would be plus tax, so yep, they've gone up.
/ Tire Prices!! Geeze #29
Chris
Chris, some 25 years ago, when fleet management was part of my job, I read in one of the magazines that while tires last longer if rotated, if you paid to have tires rotated, it would be cheaper to not do it. but since I buy my tires from Discount Tire Co., they rotate them at no cost, so I do buy 4 at a time and let them rotate them.
Now I've only asked them to rotate tires I bought there, but I recently had them fix a flat on our '02 Crown Vic that still has the Michelins that were on it when we bought it. The guy measured the tread depth and said they had 7/32, but they did not charge anything for fixing the flat, and last week sent me an e-mail to bring that car in for free tire rotation.
/ Tire Prices!! Geeze #30
Yea, I rotate my tires myself. I have 2 large jacks and my shop is set up with a compressor and air hose reels at 3 locations. It takes me about 10 minutes to rotate them on any of my vehicles. I then go back with my torque wrench and again at 100 miles.
Chris
/ Tire Prices!! Geeze #31
Its funny that this came up now.
I just bought new tires for my 1/2 ton DD. I put on Mastercraft Coursar A/T (265/75R16), because they were a "reasonable" price and I was looking for at least a load range of D (these are E's). Walked out the door at $980 for all four.
Last set was Bridgestones that I got three years and 65K miles out of. Great tires, but I made the mistake of getting one size bigger than stock (285/75R16) and they rubbed a bit. I think I paid about $750 then. Same tiree store, same serives rendered.
/ Tire Prices!! Geeze #32
My Lesabre uses 16 inchers, have to spend about $140 for an OEM quality replacement. Know what baffles me.....automakers try to reduce weight by using thinner steel, more plastic, downsize cooling systems, etc. but they keep putting bigger, heavier wheels and tires on vehicles. Does that make any sense to you?
/ Tire Prices!! Geeze #33
Chris
Smart way to do it, BUT...do you use an impact wrench on alloy wheels? I had a brand new set of alloy American Racing Wheels damaged by a shop using an impact wrench a long time ago and will NEVER let an impact wrench near any of our vehicles again. Not by me, nor by a shop.
/ Tire Prices!! Geeze #34
Every shop in the world is using Impact tools on alloy rims every day.
Good or bad, that's a fact, what do you tell them at the shop to use a tire iron?
They would laugh at you at soon as left, and go right back to using the air wrench. I understand your position on the matter, due to your experience, but don't forget some of the heaviest truck rims are alloy now.
I usually use/ need the 4 way to break the nuts loose and torque them, but that's because my compressor/ impact wrench is not capable. I do use the impact as much as I can though.
JB
/ Tire Prices!! Geeze #35
Its larger brakes and heavier cars that need the bigger brakes to meet the new requirements set forth by SAE that requires the larger wheels and tires. Just compare the size of the brakes on a 2-3 year old 1/2 ton truck to a 15 year old 3/4 ton truck and you will quickly see what I mean.
Our BMW 335I has huge brakes I would not be surprised if they are not as big or bigger than my 2006 F-350.
Chris
/ Tire Prices!! Geeze #36
Yes I do but I do it, not some idiot at a shop. I only run them on to 75 FT lbs with the impact on most things and 120 FT lbs on my F-350.
Most passenger cars and 1/2 ton trucks have a torque setting of about 95/110 FT lbs. Trailers are at 120 FT lbs. My F-350 and neighbors 3500 GMC both require 140/160 FT lbs.
Chris
/ Tire Prices!! Geeze #37
JB
The shop that had to eat the cost of replacing my $400 worth of new wheels, plus the labor charges to demount, mount, and balance my new tires used an air impact wrench just to INSTALL the lug nuts....the rims had never been mounted before and the operator was careless and let his wrench mark up both wheels and stainless center caps, on all four corners. Every since then, if I needed flats fixed or new tires, or whatever, I demount the tire and rim and take it in to have the work done. The instructions that were packed with my new rims (that the shop sold me) clearly said "DO NOT USE AN IMPACT WRENCH ON THESE WHEELS"....morons.
/ Tire Prices!! Geeze #38
The last time I purchased tires was for a 1990 F 150, back in about 1997-----REALLY !!! Paid about $65 each for premium P235-15 snows with stems, balancing, and tax. Being a really low mileage driver, tires last me forever. But right now, wifes 2004 Saturn will need a set within a year. I have been seeing prices keep rising...worries me because sooner or later I will need a set for my GMC (load range E) too...probably cost me $200 each then.
I have 195 60 15 on my saturn. The cheapest set i can get from a friend who sells me tires through a side business of his (at his cost) is $130 for 2. That is 110 for tires and him charging 10/ tire to mount and balance. They are off brand chineese whatever the best price is about 40K mile tires.
Your truck, they are $200/piece i bet today!
/ Tire Prices!! Geeze #39
Just did some checking, back in March of '95 I purchased a set of BFG Radial T/A's for my F150, invoice says tires were $78 each plus tax, mounting, balancing....current price online for the same tire..235/70-15 (load range B) is about $128 each...I don't think that is an unreasonable increase over the time period.
Look at the BFG All terrain, there close to $200 per tire in the size for your other truck.
/ Tire Prices!! Geeze #40
Saturn is an L-300, OEM size is 215/55R16....still has original Firestone Firehawks with 53,000 miles...will replace front pair next spring.
