Tire pressure
/ Tire pressure #1
smoothie17
Virginia
Kubota B2910
Added air to rear tire on back of my Kubota B2910. Inadvertently, I over inflated by about 5 pounds. When I tried to bleed the excess, only the water / sodium chloride mixture came out. The valve stem is positioned at the top of the tire so I thought only air would escape.
Any ideas?
Thanks !!!
/ Tire pressure #2
Sounds like you may have a little more liquid in the tire than you should.
I would not worry about it...but if I were to worry, I would jack the tractor up, with the valve stem at the top, and let all the air and liquid out, and then put in the amount of air pressure that I wanted.
Now if you are getting a little liquid with the air, and not all liquid, then it is probably not an issue at all...
/ Tire pressure
Thanks for the reply. Called the dealer and he said just bleed the tire until I get down to the desired pressure. I probably lost a quart or two but now I'm OK. I'll know next time to add air slower for sure.
How do you like your B2910?
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
2019 John Deere 835R Gator (A63116)
2019 John Deere...
2005 John Deere 726 Mulch Finisher (A63116)
2005 John Deere...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
2022 Magni TH5 5.19P (A63118)
2022 Magni TH5...
2015 SKY TRAK 6036 TELEHANDLER (A59910)
2015 SKY TRAK 6036...
