Tire Pressure
/ Tire Pressure #1
KTD
NE PA
JD 4310 e-hydro
This may be a stupid questions, but here goes . . .
My JD425 Garden Tractor has loaded tires. Is there any need to check tire pressure? If so, how do you do it?
/ Tire Pressure #2
What are those tires loaded with? If foam filled, no checking necessary. If liquid, then yes, sometimes the pressure may need to be adjusted. There are air/liquid tire gauges available at most auto parts and/or tractor supply houses. My preferred method is to start with the valve stem at the top (12 o'clock position), preferably, but not absolutely necessary, put a jack under the tractor and raise it enough to take the weight off the tire. And then I give mine a short burst of air from the air hose first to clear the valve stem of most of the liquid, then check the pressure and adjust as necessary.
/ Tire Pressure #3
I'm confused. Wouldn't the tire pressure you gauge with a jack under the machine taking the weight off be notably less than the pressure with the tire bearing it's normal load?
/ Tire Pressure
Thanks for the reply Bird. The tires are loaded with a liquid. I didn't know that there were tires gauges that would measure the liquid filled tires.
/ Tire Pressure #5
What does clearing the valve stem with air before checking do? Isn't that why you use the air/liquid tire guage? I have to ask because my new tractor has loaded tires, but I don't have a compressor yet. /forums/images/graemlins/frown.gif
My tires were loaded with calcium chloride (and water I presume) and tubes were put in... does this have a bearing on your method Bird?
Thanks
/ Tire Pressure #6
Freds the initial burst of air clears the valve stem of any calcium chloride, this prevents damage to your pressure guage.
/ Tire Pressure #7
Pressure in a confined space stays constant as long as the volume of the space and the temperature stay constant and no more material is introduced into the space. True, deformation of the tire under load may change the volume of the space (inside of tire) enough to impact pressure, but I wouldn't think it would be enough to be significant. My opinion is that the volume would be fairly constant but removing the load just shifts more of that volume below the level of the valve stem, making for a less messy scenario overall.
Jeff
/ Tire Pressure #8
Thanks Mike. Looks like I'll have to get an air compressor. One would come in handy anyways.
/ Tire Pressure #9
Freds,
For around $20 or less, you can buy a portable air tank that you can fill at the local gas station (or friend's house) and carry to your place to fill up your tires. Can usually handle around 115psi.
Volume of air is limited, best for topping off tires, not so good for filling from flat (too many trips needed).
A quick, cheap interim solution until you get your compressor.
-JC
/ Tire Pressure #10
Gary, I won't try to get into the technical aspects of why the air pressure in the tire stays the same whether the tire is on the ground or jacked up, but it does; at least so close you won't know the difference. Did you ever notice when you have a new tire mounted, or a flat fixed, that they air it up to its required pressure before putting it on the car? And the main reason I prefer jacking it up is just so it doesn't try to push any liquid out. Probably not necessary; just my own preferred method.
Freds, I don't even know exactly what's different about the air/liquid gauges from the air gauges (stainless steel maybe?). They look the same and not much difference in price, but the ones made for liquid don't corrode like the one made just for air will. And it may not be "necessary" to give it a short burst of air first, but I just like to clear the valve stem and get as little liquid in the gauge as possible. I know if the liquid is nothing but water, it won't hurt the gauge, but I'm not so sure about calcium.
/ Tire Pressure #11
Not so sure about the tire pressure being the same on and off the tractor. I can have 30lbs in my utility trailer tires, load about 1 ton of firewood on there and have 38 lbs or so of air pressure in them.
/ Tire Pressure #12
Jeff had it right - JUST introducing outside pressure will not change the inside pressure IF the volume doesn't change. But how much the volume does change is going to vary tire by tire, load by load, radial or bias, etc.,
In my experience, normal auto tires seem to have very little difference on or off the car. My GT tire's don't change on/off. Like slowrev said, I've seen trailer tires (undersized for the load) show a difference. Still waiting to get an air/water gauge for the bigger tractor, so I don't know how/if they're effected yet. Simplest test for your tractor tires - try it both ways at least once and compare. To paraphrase Yogi - "you'll know when you know, then you'll know".
/ Tire Pressure #13
</font><font color="blue" class="small">( To paraphrase Yogi - "you'll know when you know, then you'll know". )</font>
When did he say that, before or after he stole the picnic basket?
/forums/images/graemlins/crazy.gif
/ Tire Pressure #15
</font><font color="blue" class="small">( Wrong Yogi. /forums/images/graemlins/tongue.gif )</font>
It is the age problem...... the youngster probably wasn't born when Yogi said that.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Learn more about Yogi at this web page
/ Tire Pressure #16
Oh THAT Yogi /forums/images/graemlins/grin.gif and I thought you were talking about the bear. /forums/images/graemlins/wink.gif
I would bet money that the bear was around long before the Berra, so I don't know what age would have to do with it, but thanks for calling me a youngster.
/ Tire Pressure #17
JeffRey did a good job with the technical explanation. Thanks, Jeff. /forums/images/graemlins/smile.gif This is just another of those times when I wish I'd taken a couple science and physics classes along the way. /forums/images/graemlins/crazy.gif
/ Tire Pressure #18
The Yogi you were thinking of debuted in 1958. To learn more about him, please go to this web page .... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Tire Pressure #19
Both Yogi B and Yogi the B aside, I wish I'd read these posts before I checked my tires and wondered why fluid was coming out the value stem even though it was at 12 o'clock. I'll remember for next time.
Thanks Guys!!!!
Eric P.
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
5-Pointed Star Metal Decorative Sign (A64557)
5-Pointed Star...
