Tires tire pressure
/ tire pressure #1
kubota L3200; john deere lt190
can anyone tell me what the recommended tire pressure is for the rear tires on the L3200 with ag tires
sorry for this stupid question
/ tire pressure
never mind i found my manual its always in the last place you look
/ tire pressure
Just in case someone else has the same question....
What did you find?
14psi for the rear and 26 for the front
i have a 4 wheel drive but i dont think that make any difference on tire pressures
/ tire pressure #5
because I got tired of rolling my fronts off the rim, I keep them at least 30.
/ tire pressure #6
If your L3200 has a loader mounted, you're going to want 35 psi in the fronts and not 26.
I've had front tire problems with my L3400 because of that, check either your loader manual or the tractor manual, there should be different specs for loader use.
With a full bucket of gravel or rock, the fronts are nearly flat with only 26 psi in them, and will tear up the sidewalls when turning, enough to seriously damage the structure of the tire.
I've had no problems with the second set of tires at 35-36 psi (maximum recommended pressure on tire sidewall).
Sean
/ tire pressure #7
Be careful when exceding the recommended air pressure especially when using a front end loader or you'll probably become your local tire dealers best customer.
On compact tractors the number one killer of the front tires is failure due to impact break in the casing from being over inflated so that it doesn't flex so bad, and the least little rock or hard bump and the tire will split wide open.
It will split in an "X" or "Y" pattern and is a dead give away for that classical failure.
I've stood right next to my cousin's Kubota when the tires folder over flat sideways and never hurt them at all at proper pressure.
Tired
Caterpillar D7R Dozer Service and Parts Manuals (A63117)
Caterpillar D7R...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2009 Caterpillar 345D Hydraulic Excavator (A61572)
2009 Caterpillar...
Caterpillar CP-563/CS-563 Parts and Service Manuals (A63117)
Caterpillar...
2017 BOBCAT MT55 STAND-ON SKID STEER (A64279)
2017 BOBCAT MT55...
