Tire loading AGAIN!!
/ Tire loading AGAIN!! #1
B7500
Platinum Member
Tupper Lake, NY
Kubota B7500 HSD
Any ideas why my dealer is trying to talk me OUT of filling my tires? He claims that the weight of my BH is enough. Do you think he is right? All I know is I can't completely fill my bucket with dirt without the tires spinning even in 4wd. I also think the lower center of gravity would be nice on my slopes. I have a B7500 which is not a huge tractor.
/ Tire loading AGAIN!! #2
<font color="blue"> All I know is I can't completely fill my bucket with dirt without the tires spinning even in 4wd. </font>
You told him this, right?
Mike, Actually no. Probably should have. He just said with the size of my tires I'd only gain a couple hundred pounds. Not enough to make a difference.
/ Tire loading AGAIN!! #4
I guess he's thinking in comparison to the weight of the backhoe, a couple hundred pounds isn't much. What's the backhoe weigh?
/ Tire loading AGAIN!! #5
200# ~ 10% of the tractor weight. I'd say that's a noticable difference. I got mine (TC18 similar in size to 7500) loaded with Rim Guard (heavier than CaCl Or washer fluid). It made a difference.
/ Tire loading AGAIN!! #6
Tawoo,
I'd agree with your dealer, if you never take your backhoe off. I assume it is removable, and you will want to work with your tractor sometime without it on. Like if in tight quarters somewhere. You'll want that weight then. Tell the dealer this is what I want done. On this topic I want your work, not your opinion.
Better yet, look up some of the threads that describe how to do it and do it yourself. With the outriggers, jacking up the tractor to load the tires would be real easy.
Nick
Hazmat,
Always good to hear from you. It did make a difference huh? I may just do it. What harm can it do except loose a few $$ out of my wallet.
Thanks!
/ Tire loading AGAIN!! #8
If I may add a bit as well...
Although the backhoe does add quite a bit of weight, a good part of the weight is above the center of gravity of the tractor, so while it improves the traction of the rear tires, it probably does not help overall stability as much as you would expect from such a large weight.
The weight from the filled tires is most likely completely below the center of gravity of the tractor, so it can only help with stability. As for additional traction, again it can only help.
I have a Woods 7500 on my B2910. I haven't filled the rear tires yet, but I'm thinking about it. I can "sense" a difference in the stability of the tractor (tilting on its side) between the backhoe and a 550 lb. boxblade. The boxblade feels more stable, but I probably get better traction with the backhoe.
I vote for filling the tires.
~Rick
/ Tire loading AGAIN!! #9
Tawoo,
You can fill your tires yourself very easily with windshield wiper fluid very cheaply. I have seen the little drill powered pumps sold for as little as $3, but actuallypaid $6 for mine...
There are a couple theads here that describe the process. With the backhoe it is really simple, because the stabilizers take place of the need to jack the back end up.
Bottom line, in my opinion, is that it can only help, can't hurt, and if you do it yourself, you get the feeling of accomplishment and save some bucks too.
Go for it!
Henro,
Thanks for the encouragement to do it myself. I think I will try it and let you know how it worked out.
Rick Jay,
I agree the better stability is a definite plus.
MDNick,
Thanks for your input.
/ Tire loading AGAIN!! #11
Tawoo,
Be sure to read my posts ("Tire Loading Trouble") on the experience I had loading my tires. I have the same machine as you and had to learn the hard way. Our tires (12-16.5) require tubes and at least 30lbs. of air pressure. They are a different type of wheel and will not hold a bead at lower pressure.
Good Luck,
Greg
Greg,
When you say our tires require tubes do you mean we have them now or you had to add them to load the tires?
I have no problem letting the dealer do it and paying the bucks but I just want to make sure it would make a difference and not be a waste of money.
Thanks for your reply.
/ Tire loading AGAIN!! #13
Terry,
The tubes have to be added. It cost me about $18 each, installed. I installed the ww fluid. I finally had the method down on the second tire. Since the tubes are industrial, not Ag, they don't have a threaded stem, so the only thing holding the stem in place is the internal air/fluid pressure. One tool that would have made this process a little easier would have been a hemostat, or some very slender locking plier that you could lock on the valve stem while you were filling and replacing the valve. I used a pair of needle nose with a hose clamp holding it in place. It worked, but I think there is a better tool. It has to be very slender, because the stem guard on the rim has very little access. After you fill the tire, be ready for the "water balloon" effect when you remove the adapter and put the valve back in the stem. Have buckets ready under the wheel. My first wheel all I had was a towel and I was holding the stem with needle nose pliers with my right hand and trying to screw the valve in with my left with fluid flying everywhere in my shop and I couldn't let go of the pliers. Fortunately for me, the shop door was closed and my wife was nowhere is sight. Otherwise I think she and the neighbors would still be laughing. That is why it is important to have both hands free when you get to that stage. One good thing is I ended up with the shop floor cleaner than it's been in years.
I mentioned in my earlier post about tire pressure. I started out with about 12lbs. pressure. When I test drove the tractor to the end of our road and back, the tire and tube spun on the rim and buried the valve stem sideways in the stem guard. That was a lot of fun to fix. After returning to the tire shop one more time I learned that this type of rim and tire require at least 30lbs to stay seated.
Now that it is done, if asked would I do it again? ..... Probably. It is a relatively inexpensive process that might add a fraction of extra ballast that I might need someday. Hopefully I will be smart enough to never put myself in a position to need it, but I like knowing it's there. Good luck.
Greg
/ Tire loading AGAIN!! #14
<font color="blue"> Tawoo,
Be sure to read my posts ("Tire Loading Trouble") on the experience I had loading my tires. </font>
Good point GregJ!
I forgot about your sad story, as it was so different from my tire loading experience I guess!
I wonder if for some reason you just had bad luck...or if ALL guys with those 16.5 inch wheels have the same problems. My B2910 rear wheels are tire size 12.4 x 16...
Tawoo after remembering GregJ's tale of woe, I would at least post a question here asking other b7500 owners if they had success loading thier tires themselves before undertaking the job myself. [Trusting my memory here on the tractor size but as I type this I think that is what you both have].
In many cases you just let the air out and pump the fluid in and you are done with it. I still can't believe the hardship GregJ went through... I think it would scare me away from trying it myself unless I got some reports of others with the same tractor being able to do it their selves without problems...
/ Tire loading AGAIN!! #15
I'm no expert but I'll throw my 2c in. I loaded the rears on my L3010 last year. My dealer talked me out of it at first as well. However after nearly rolling over after I had a bucket full of rocks heading across a field (front right tire dropped in an unseen hole), I decided to do it anyway, lawn compression be damned. I went the washer fluid route and other than getting all the bottles home from WalMart, it went fine. By an extra bottle or two more than you need before you start to allow for "shrinkage" between bottles. I just followed the same threads I'm sure you found. The key is not letting the bead break on the rim, jack the wheel up completely. Also make sure to check the freeze rating on the fuild so you don't get the summer mix.
This made a big difference in stability and traction for me. I definately don't regret doing it.
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
2010 GMC W5500 HD 16FT Box Truck (A61573)
2010 GMC W5500 HD...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
