Tires Tire Inflation procedure
   / Tire Inflation procedure #1
ham1
Hey anybody out there can expalain on how to add pressure to a tire that is low?
It really sounds stupid but it is a liquid filled tire and I though I could get my compressor out and bring it up to normal with that.
When I uncrewed the valve stem cap, and began to put pressure in the tire, liquid began squirting out and I had to put the valvr stem cap back on.
What gives? I know this cant be that difficult. It is a tractor I inherited so I am new to this.
Thanks in advance
   / Tire Inflation procedure #2
The tire should have only about 75% fluid, so check the air pressure with the valve stem positioned above the fluid line from about the 10:00-2:00 position.
   / Tire Inflation procedure #3
It sounds as if you have a bad valve core. Even with the valve stem at the bottom, the core should not leak with the valve cap removed. So, personally, I'd jack it up to take the load off that tire, rotate it so the valve stem is at the top (12 o'clock position), then remove the valve core and replace it. Then add the air to it.
UNSUED CFG INDUSTRIAL SSHH680 BREAKER (A51244)
UNSUED CFG...
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52128)
1994 Thomas Built...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
