Tire Disposal
/ Tire Disposal #1
Joe1shoe
Pennsylvania
JD 4710
You guys have advise on how to dispose of old tractor tires (legally)? I tried giving them away as sandboxes. No go. I tried the local tire disposal day. Noop. They said they don't take commercial tires. I have 12 of them.
I'm all ears........
/ Tire Disposal #2
my area the do a once a year tire collection. id take them there.
Explain that "im trying to do the right thing hear, and if you dont take them i cant guarantee they wont "fall off" on the way home."
/ Tire Disposal
I'll try again. They wern't too nice last time. They reminded me the fine for dumping is $300 per tire.
/ Tire Disposal #5
Ask a local tire dealer. They have to dispose of their tires somehow and hopefully tell you the company they use. I would guess it will probably cost you a bit to get rid of 12 tractor tires.
Our county has a tire amnesty day once or twice a year, but they generally set limits on how many and what kind as well.
/ Tire Disposal #6
Do you have a brush pile that needs to be burned? I'm all for doing the right thing and recycle if they will let you, but it seems you have tried with no luck. I say, burn baby burn!
/ Tire Disposal #7
cut the bead out.
cur them in half so you have 2 donuts.
stack one donut inside the other.
use as earth anchor in an erosion gully.
set one on the bottom, stake with rebar, fill with dirt, stack next one, repeat until you're about 12" from the top and cover with topsoil. Stepping back 18-24" per tire helps build a stable slope as well.
/ Tire Disposal #8
We have a tire shredding plant here in Jacksonville, but I don't know if they take tractor tires. They also make that rubber mulch.
/ Tire Disposal #9
Aggiehortguy91 suggested asking a tire dealer. They should be able to help you out by adding your's to their's. Hopefully you would just have to pay their cost. Place that sells tractor tires would be able to handle that or maybe just a dealer you have dealt with.
But I might continue to gently try the local government offices to see what they suggest. Make sure they understand you are not commerical but just trying to do the right thing with problem you inherited.
/ Tire Disposal #10
cut the bead out.
That is a good idea!!
/ Tire Disposal #11
Our MNR biologist had a fit when I suggested doing that to cure the erosion along our driveway. (It was washing into the lake)
You could lay them down and pour them full of concrete, embedding a pole into them for a flagpole, or as bases for polebarn poles, etc. They could then be moved and reused in future (if you have a big enough loader). We used to do much the same with car tires on a smaller scale.
2021 John Deere 3046R Tractor Loader (A63116)
2021 John Deere...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
17394SFL (A61568)
17394SFL (A61568)
Vermeer 604 XL-Series (A62177)
Vermeer 604...
John Deere Z994R (A60462)
John Deere Z994R...
Big Tex Trailer (A64047)
Big Tex Trailer...
