Tire chains
/ Tire chains #1
Nuklbuster
Mason Wi
JD 2025r
I've got a JD3320with R4 tires, this winter being what it is I'm having traction issues when I plow. I'm looking for tire chains, they need to be low profile for fender clearance. I looked into Aquiline but they are sold out until fall. Any other brands out there, possibly dealers in the Midwest?
/ Tire chains #4
I would wait till the Fall, as the Aqualines are super. If not try Trygg chains. They are comparable, but probably a little more money, if you can believe that. I'm sure you have already priced the aqualines. I have them and they are great chains. Really seldom use 4WD when plowing now.
/ Tire chains #6
I have Aquline Talons. I would hold out for them. Expensive yes. But after this winter they have been worth their weight in gold. From my experience Aquline chains that are sold out are not typically back in stock until September before the next winter.
/ Tire chains #7
have you tried sipping your tires?? Makes a world of difference for very little cash. I would do every other lug. Maybe try this before chains. But its all up to you. THis winter has been rough
/ Tire chains #8
Siping may help, as would having filled tires (OP got 'em?), and IMO a hefty box blade is the default minimum counterweight to the FEL in winter. Siping pattern pics on pages 6, 12, 19, ... here:
http://www.tractorbynet.com/forums/snow-removal/193438-cutting-groving-siping-r-4-a-6.html
Two-link chains are almost a given on smaller diameter tires (mowers, etc), but IMO 4-link may be fine on CUTs. It's easily possible to become stuck even with 4WD & chains, with pedal stomping and side sliding often a part of recovery. Be sure if using bungees or springs for tension that spares are close at hand.
I'm sure quality chains are worth the $$, but I've seen only the cheapest in use and wonder if it's the fasteners (vs magical matls/configs) that are a big part of that justification. I doubt that any brand/quality chains would be hard to 'patch up', but never saw any that needed much fixin', either ... :2cents:
/ Tire chains #9
Try www.tirechains.com
But don't be surprised if quite a few of the chain sellers are out of stock. It's late in the season.
Good luck!
/ Tire chains #10
I can't imagine plowing snow with a 4WD tractor and not having it in 4WD all the time. If not now ,when? Not only do you have more "push" but the breaking forces get spread over all four wheels through the front drive shaft. When your sliding down hill towards that drop off you want all the claw back you can get. I haven't had mine in 2WD sense hunting season.
/ Tire chains #11
Me too. I use 4WD all the time in winter and when I start to spin, that is when I stomp on the power divider pedal.
/ Tire chains #12
I went with the Duo's from tirechains.com. Was worried about the chains staying on top of the lugs on my R4's. The Duo's seemed to accomplish that pretty well. Glad I had them this winter.
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
