"Does moving the wheels out farther have the potential for damaging the axle in anyway, adding additional stress to any components? I'm curious as I have the
B3030 cab tractor (with loaded rear tires) and really question the integrity of the axles."
Just spoke to a Kubota rep (late Jan 2011) about my (loaded rear tire)
b3030 hsdc regarding chains and spacers...
then saw your post... the rep noted it all depends on the chains you buy... some of the aggressive chains will catch on the tractor... some of the finer "ice" chains will be fine. I have R-4 tires that are (I believe) a bit smaller in some dimension than the turfs... As far as spacers the rep noted that kubota recommends no wider than the 1.5 inch spacers... i did not press him on this but I have seen wider ones on eBay... one interesting item noted was that he does NOT recommend chains on both the front and back as the tractor is designed in such a way that this double chain application can harm the drivetrain...
The spacers from kubota were about $280.
Chains can be 3-4-5+ hundred.
Anyone found good less costly chains... ?
thanks...
