Tire Chains
/ Tire Chains #43
Does anybody know if the any other size chain will work for an R4 size R15-19.5?
Depends on if you're willing to modify them. 15-19.5 is a very common R-4 tire size.
Did tirechains.com have any other types of chains in that size? 2-link ladder chains might work for you. Also, if your drive is asphalt or concrete, you might want to reconsider the v-bars.
/ Tire Chains #44
All gravel road...mostly mud right now. TireChains.com has been out of stock right now. Been checking back and hoping that I get an order in before the next big snow. Here's a picture of my driveway of an attempt of scraping the snow.
/ Tire Chains #47
TB1529 - How have you dealt with the driveway in years past? If it were me I'd stick it, place the order for the V-Bar, if they come in this year great. If not then you will be prepaired for next winter. Just my 2 cents. Which now days might be worth a wooden nickel
Wedge
/ Tire Chains #48
I was in the same boat your in, last year. I did not get my chains till April. That being said, The chains were great, and the price was right. I went with the Duo, style. You might get lucky, but I would not count on getting those chains in the next three months.
/ Tire Chains #49
Would a ladder style chains work good enough to pass over the V-bars for my driveway?
The ladders would be better then no chains, but I'd suggest you go with wedge40's advice to go with what you have this winter and pick up the v-bars come Spring.
If you do go with those ladder chains, the 2-links would be better then the 4 link (with that sloped drive) and learn to use your brakes for steering (as well as the 4WD, if you have it).
If you are determined to get chains, don't put it off too long. Reckon they'll be out of stock pretty soon.
/ Tire Chains #51
Ladder chain would work fine for you. V-bars work good for ice, but ladder will do 95% of your chain needs.
/ Tire Chains #52
Thanks for the replies. We're getting another round of bad weather here. The V-bars just became avaible on tirechains.com, wouldn't be here for this round, but I'll be ready next time. Thanks ya'll!:thumbsup:
/ Tire Chains #53
I just can't see how ladder chains would do anywhere near the job of V-bars (which I just ordered). The ladder chains only stick up a little bit out of the grooves on R4 tires, and in any case a straight link chain is a rather slippery surface, whereas the V-bars are made to viciously attack the ice, and the H-link structure keeps them up on top of the lugs. It just seems like it would be night and day to me.
/ Tire Chains #54
The H pattern does keep the chains with contact on the ground all the time. I think this gives a better ride and better traction. A chain with V-bars is going to give better traction than a smooth chain. On ice and everything else.
/ Tire Chains #55
There may be a big difference, but I've never found the ladder chains not doing the traction job at hand.
So hitting something with a bigger hammer when it isn't necessary seems to me to be a waste (or overdoing it). :)
I just want to help out with the information and experience I have accumulated over 40 years keeping the drive and lower roadway open in southern WI winters. And the slope of the drive is 12% in one section, has often been iced over and drifted in with 3-5' snow drifts and ice underneath. Also, the ladder chains work in 12" of snow in the woods which is a hillside. The ladder chains properly fit do not drop off the top of the lugs.
Only trying to be helpful here. I don't have a problem with anyone waiting and spending their money for the v-bars on their chains. :D
Not one iota.
/ Tire Chains #56
Not one iota.
Holy smokes, beenthere, you really have helped out! How the heck did you ever get to over 8,000 posts? And thanks for so much contribution to TBN - folks like you make all the difference, and so many have been helped, including me.
Meanwhile, maybe I did splurge on the V-bar chains, but my motto has always been "good enough....isn't!" So, when I saw the killer V-bar chains on canadian chains.com, I just couldn't resist! And I had already bought and returned ladder chains, after trying to fit them on my BX25, so.....:eek:
/ Tire Chains #57
Know is half the battle. And I rather know too much then jump in blind. Order some V-bars all the way around. If I can't get up and down my driveway now...I'm going to move! Thanks everybody for all the input.
2017 International 4300 Box Truck (A62613)
2017 International...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
