Tires tire chains
/ tire chains #1
Ranger545
Adirondacks
I have a new DK35 with loaded R4 tires. I tried to mount a set of tire chains and realized there is no clearence between the tire and fender support, so no room for the chain. What should I do, put chains on the front? I will be using them for loader work on my icy driveway.
/ tire chains #2
Ranger, I sent you a PM.
But for anyone else that is inquiring Kioti does offer spacer plates for the DK35SE
Part#T4125B58500101
/ tire chains #3
Rich, Do you know if Kioti offers a wheel spacer kit for LB1914. I have the same problem with chains not fitting because of the fenders. Jim
/ tire chains #4
The LB1914 does have a different problem, The lb tires are close to the fender on the top of the lugs, the dk has clearance issue inside.
I am unaware of any thing that will help the LB.
/ tire chains #5
Will chains fit on a CK30 with Industrial tires?
/ tire chains #6
They do on mine, pics show in the middle of the page. I have one link on my left rear tire that is loose and hits the fender if I am zipping along in high, other than that, no issues.
CK30HST
/ tire chains #7
No problems on any of the CK series tractors unless equiped with a Woods 4 point mount backhoe.
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
Bush Hog RDTH84 (A64126)
Bush Hog RDTH84...
1024 (A63111)
1024 (A63111)
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
