Tire chains-looking for opinions.
   / Tire chains-looking for opinions. #1
robmc
Foster,R.I.
john deere 770 70 fel 7 bh
I am in the market for a set of chains for my tractor. The tire size is 13.6-16. Any recommendations on where to purchase, style or manufacturer? Is there a better style or brand of tensioner?
   / Tire chains-looking for opinions. #2
I got a set of tractor chains from these folks. Good chains and good service. Avoid the V-bar if you have concrete or asphalt.
https://tirechains.com/
   / Tire chains-looking for opinions. #3
There are a ton of threads on TBN about tire chains and many about different type of adjusters.
Try putting "tire chains" in the Google search box at the top right of the screen.
Also figure out what you want them for, snow, mud, ice?
I too bought mine from tirechains and I just use heavy duty black EPDM tarp straps from HF.
But you might want to get your order in soon because chains sometimes sell out.
   / Tire chains-looking for opinions. #5
Another vote for tirechains.com, I use rubber tensioners on front and the spring tensioners from TC.com for the rear wheels. I plow a gravel driveway and a dirt road with some grade issues so I went with v-bar. I have had no problems even when it gets icy. I use OSB to protect the floor, I'm on my third winter with the same OSB.
   / Tire chains-looking for opinions. #6
I use Aquiline MPC chains on my rear tires. Bought from Champlain Valley Equipment, Middlebury, VT.
They are good for snow/ice, but not designed to be used in the woods for the most part.
My tractor is four wheel drive and I have R-4 tires on it. Would you recommend using chains on both axles?
   / Tire chains-looking for opinions. #8
I'd recommend on both axles if you have much ice and/or hills.
   / Tire chains-looking for opinions. #9
I'd start with the rears and if you find it's inadequate then go for *fronts too. (*Not really recommended because of the way the wheels turn when in 4wd and the different axle ratios). YMMV.
   / Tire chains-looking for opinions. #10
Joeyd,
I just bought chains for my tractor (about 9,000 pounds with both the loader and rear blade) and am planning to also put down wood to protect the garage floor, but I'm concerned that the OSB won't stand up to the melting snow on the floor. Do you think the OSB will be adaquate?
2025 12V Diesel Pump and Hose with Meter (A50323)
2025 12V Diesel...
John Deere 3038E (A50120)
John Deere 3038E...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
