Tire Chain Tensioners
/ Tire Chain Tensioners #21
Whistlepig- That is a good looking set of chains. $$$$ Where did you get those?
These are Aquiline Talons. Sean has the Tellefsdal chains. Some call the Tellefsdal chains the "Norse" chains. The Aquiline and Tellefsdal chains are almost identical. I like the cross link set up a little bit better on the Tellefsdal chains that Sean has. Tellefsdal is unavailable in my area so I went with the Talons. The Talons aren't cheap. $450.00 a pair for 12.4-16. Plus $150.00 freight. But it made my tractor almost unstoppable. It's almost like having steel tracks. Secure Online Shopping for all of your Tire Chain needs
/ Tire Chain Tensioners #22
As I recall I bent the hooks open, shortened the side chains, re-attached the hooks and squeezed them shut again. I had to cut out one or two of the center sections too. If you don't have room to get the levers in, you may have to put the hooks in two links apart on the side chains near the ends instead of three.
It looks like you have about the right amount of wrap around the sides of the tire, if the side chains were shorter you'd be fine I think.
Sean
Thanks. Its nice to know that you fitted them. Yours looks much too clean and neat to be out of the box from the factory.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
GIYI Skid Steer Mount Stump Grinder  (A62679)
GIYI Skid Steer...
2013 Infiniti JX35 AWD SUV (A64557)
2013 Infiniti JX35...
East Texas Gooseneck Trailer (A65563)
East Texas...
6ft Kodiak Extra Heavy-Duty Rotary Cutter (A65579)
6ft Kodiak Extra...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
