Tire capacity
/ Tire capacity #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Can anyone tell me exactly how many gallons of liquid the 20" rear tires on a 3038h will hold. I only need to get protection down to about 20 degrees where I'm located so not a lot of antifreeze will need to be added. Thanks.
/ Tire capacity #4
what is the tire size? a lil info helps us to get you more info..
/ Tire capacity #5
Due to the rather large mass of liquid it is the average day/nite temperature that determines whether a tire will freeze at all ... or enuf to matter. If your lo -- nite time temp is 20°F it is not likely you will ever freeze plain water enuf to matter.
larry
/ Tire capacity #6
This is an excellent question. Has anyone seen a chart, by tire type (R1, R4, turf) by tire size, that show tire volume on a rim? I think standard is to fill to about 75% but total volume would be a great planning tool to make sure you have enough fluid available when filling rears. We used to jack tractor, put valve stem at 12 o'clock and fill to stem level.
Thanks
Rick
/ Tire capacity #7
yes.. there are tire ballast charts out there. that's why i asked the OP what his tire size was so i coul give him fill volume at 75%
he chose not to post tire size however.
/ Tire capacity #8
yes.. there are tire ballast charts out there. that's why i asked the OP what his tire size was so i coul give him fill volume at 75% he chose not to post tire size however.
Soundguy;
Can you post a link to the tire ballast charts? This is good general information for all of us.
Thanks in advance.
Rick
/ Tire capacity
Op here. The tire is 43 16/20. Thought the orig post had enough info. Ended up putting 4 gal on each side with a siphon pump with valve stem at 12 o'clock. Sort of had to guess on the amount of water, did'nt want to over fill and lose any of that $11 a gal antifreeze. Think I'm close to the 11-2 o'clock level position
But not sure. is there a spill proof method to determine fluid level?
/ Tire capacity #11
/ Tire capacity #12
I thought post 9 said he pumped in 4 gallons or about 10% of what it could hold.
/ Tire capacity #13
Yeah you are right Jim, missed his response. Don't understand 4 gallons either?
Rick
/ Tire capacity #14
what's the new metric designation tire size?
/ Tire capacity #15
i find a 43x16.00-20 NHS not sure if that is what he has in turf?
/ Tire capacity #16
Soundguy;
Thanks in advance.
Rick
take your pic. 54000 hits come up on google.. :)
/ Tire capacity #17
Rick
Someone sent me a note. The read between the lines I did not grasp was he pumped in some antifreeze and then topped it off with water. That should give him plenty of ballast and freeze protection.
/ Tire capacity #18
here's what my chart shows
75% Fill
· Straight Water: 52 gal
· Water & 3.5lbs/gal: 41 gal
· Water & 5lbs/gal: 38 gal
/ Tire capacity #19
RimGuard tire fill tool: https://www.rimguardsolutions.com/tire-fill-tools/
According to it one 43X16-20 tire holds about 41 US gallons at 441 lbs.
Norco says "38 gallons, 410 pounds per tire, for rear tire size 43x16-20 R4 ; total of 800 lbs." (includes 3038E)
Another vendor says 52 gallons - that might be totally filled. (See Tera Tires)
Old thread but filling this in just in case someone else is searching.
/ Tire capacity #20
On my tractor, I have the same size tire.... R4, took 40 gals each to fill to the stem at 12 o'clock. I used -20 windshield washer fluid.
