Tire capacity
/ Tire capacity #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Can anyone tell me exactly how many gallons of liquid the 20" rear tires on a 3038h will hold. I only need to get protection down to about 20 degrees where I'm located so not a lot of antifreeze will need to be added. Thanks.
/ Tire capacity #4
what is the tire size? a lil info helps us to get you more info..
/ Tire capacity #5
Due to the rather large mass of liquid it is the average day/nite temperature that determines whether a tire will freeze at all ... or enuf to matter. If your lo -- nite time temp is 20°F it is not likely you will ever freeze plain water enuf to matter.
larry
/ Tire capacity #6
This is an excellent question. Has anyone seen a chart, by tire type (R1, R4, turf) by tire size, that show tire volume on a rim? I think standard is to fill to about 75% but total volume would be a great planning tool to make sure you have enough fluid available when filling rears. We used to jack tractor, put valve stem at 12 o'clock and fill to stem level.
Thanks
Rick
/ Tire capacity #7
yes.. there are tire ballast charts out there. that's why i asked the OP what his tire size was so i coul give him fill volume at 75%
he chose not to post tire size however.
/ Tire capacity #8
yes.. there are tire ballast charts out there. that's why i asked the OP what his tire size was so i coul give him fill volume at 75% he chose not to post tire size however.
Soundguy;
Can you post a link to the tire ballast charts? This is good general information for all of us.
Thanks in advance.
Rick
/ Tire capacity
Op here. The tire is 43 16/20. Thought the orig post had enough info. Ended up putting 4 gal on each side with a siphon pump with valve stem at 12 o'clock. Sort of had to guess on the amount of water, did'nt want to over fill and lose any of that $11 a gal antifreeze. Think I'm close to the 11-2 o'clock level position
But not sure. is there a spill proof method to determine fluid level?
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
2020 SAVANA 3500 4X2 S/A 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
2017 Load Trail 3.5 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2024 Linx UT357710TG (A60463)
2024 Linx...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59906)
2018 FORD TRANSIT...
