Tips to reduce property maintenance workload
   / Tips to reduce property maintenance workload #11
My approach for property maintenance is if I can’t mow it I don’t want it. Sure I don’t have the most manicured place around but I don’t spend much time or money towards the cause.
   / Tips to reduce property maintenance workload #12
A coyote is going to get through most fences. I personally don't see a problem with a bit of grass near a fence.
   / Tips to reduce property maintenance workload #13
There are also various 3ph devices you can use to weed wack under the fence line. They have various degrees of working well or not.
We are putting in several thousand feet of fencing for horses. I am 90% sure I a going with spraying. I know a lot of people then live by the motto - spray cheap and spray often. I will likely try one of the barrier products to see if we can keep the growth down for a year at a time. Even if I get 6 mo out of it that means really spray once per year given the winters we have....
   / Tips to reduce property maintenance workload #14
Shotgun for coyotes, bring dog inside at night, invisible fence or containment collar for dog in daytime. Or get a BIG dog to 'wrastle' with the coyotes!:eek:
   / Tips to reduce property maintenance workload #15
Tallgrass prairie! We have a good chunk of our property in prairie. Mow or burn in the spring and that's it. Changing landscape throughout the year and plenty of cover for wildlife.
   / Tips to reduce property maintenance workload #16
A couple of thoughts. Mow less often. There are parts of my lawn that I can mow every other time. I often adjust how often I mow not based on how it looks but if I feel like doing it or not. I try and keep the place nice but within reason. I also only weed eat three or four times a year. I also have learned to only use roundup on stuff I don't ever want grass to grow, like a gravel driveway or really obnoxious plants, like poison ivy or honey suckle. If you don't keep using the roundup nothing but weed grow up after you use it.
   / Tips to reduce property maintenance workload #17
I will 2nd the "let the lawn go dormant when it wants" thing. My neighbors with sprinklers are out there mowing every weekend (sometimes midweek too if we get really good growing weather). I have gone the whole length of August without having to mow when the grass just stops. Sometimes I might still have to knock the weeds down to grass level (my lawn is "diverse", I just mow whatever is there).
If you do do this, take a quick walk around survey before you resume mowing again...I have bumped a sapling and woken up a hornets' nest that I might have seen had I been mowing more often, or more observant.
My uncle did me one better though...too busy one year to keep his yard mowed, he finally just baled it. I think Dad did his back yard with the cutterbar a time or two as well. If nothing else, it gave him something to throw around his potatoes and tomatoes.
   / Tips to reduce property maintenance workload #18
Make things more park-like and less ornamental (useless) things like wishing wells, unused benches, gazebos!
Keep it clean, uncluttered and simple. Trim trees nice and high so your not driving through the dammmed branches. I also removed all unused fences.
A very tiny part of my place. Maybe 2% So yeah, you need the right equipment and do it smart. My lady friend hates my dishes. Hey, my place, my rules!
   / Tips to reduce property maintenance workload #19
Ideas to reduce property maintenance:
Grass can be a lower-maintenance option because theoretically you just zip your riding mower over it and you're done and it looks nice.
However, if it's a constant struggle to keep your lawn looking nice (sprinklers ARE constant maintenance) or if the mowing itself is just a chore you'd rather reduce, then start reducing the amount of lawn. One idea: pick an area of grass that is the most trouble to you, i.e., won't grow well, hard to mow, etc., and create a large planted bed. A roundish but slightly irregular shape is best because you won't have to try to maintain straight lines, or a perfect circle. Plant it thickly with native plants. A nice arrangement is a native tree or two (depending on the size of the bed) that doesn't get too large, surrounded by native shrubs or tall ornamental grasses, surrounded by some lower ground-cover type plants. This will give you a classic "three level design" that will be lovely and balanced. Mulch it thickly. Once things grow in you won't have trouble with weeds (they need sun) and you can just mow around the edge.
In the pic below, the clump of trees & bushes in the center, I never have to touch. Mother Nature landscapes it to her liking and I think it's lovely. We call that a "parklike setting."
Edging. The downside of lawn grass is edging, one of the worst chores, and it also looks bad when neglected. Without any pics of your property, a couple of general comments. Consider planting rows of liriope or short native grasses that will flop over the edge. You can just mow around this edge and once it grows in a bit, this "living border" will keep your grass from creeping into your beds. I'm attaching a pic of one example. Any kind of *raised* border (like stones or curbs) will always require edging. So make your edging almost flush with the lawn, perhaps just an inch higher, and you can just mow over it.
For pastures that aren't being eaten by stock, a few shade trees sprinkled throughout will really reduce the growth rate of grass, eventually. Better still, and quicker, why not let some revert to natural meadow full of wildflowers and butterflies and birds? You can mow nice curved paths around it, and it looks very nice.
EDIT: Industrial Toys posted a very nice pic of having a meadow next to a mowed area. As long as you mow a neat edge around it, it looks quite nice!
And as for the pond, this is just my taste, but I think almost nothing is so unlovely than a bare pond that's just a dimple in the ground. Why not let grasses, bushes and trees grow up around part of it? Then you can just mow one part for your view of the pond from the house.
Fencing. Whole lotta edging work on a fence. Ideas: again, plant some shrubs or ground cover or even trees all along the fence line. Or locate your fence in a wooded or shady area.
Maybe herbicide is "once and done" in Texas and CA. Here, stuff grows back pretty quickly. There's a now a big lawsuit against Monsanto by a whole bunch of cancer patients.....we'll see what happens. But that stuff never leaves your body. Maybe if it actually *worked*, I'd consider carefully applying it during a dry period while wearing a respirator and consider it worth it. YMMV
Sounds like you're trying to maintain a smooth, green, groomed perfection. That will always be a lot of work. So as a general comment, why not incorporate a little imperfection into your overall scheme and just sort of "groom it around the edges"? Also, anything that needs watering is *out* as far as I'm concerned. Stick with natives that can fend for themselves.
This could all be wildly off base for YOUR property (pics would help) but the principles I think are sound.
   / Tips to reduce property maintenance workload #20
That is my philosophy and an argument with my wife till I got fed up and handed her the weed eater. Then she came around to my point of veiw :D
Kawasaki NR (A50324)
New/Unused 13ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 13ft X...
2012 LAMAR TRAILER 20 T/A UTILITY TRAILER (A55745)
2012 LAMAR TRAILER...
Peterbilt 377 Semi-Truck (A55302)
Peterbilt 377...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
