rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,478
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Mebbe not ...... This whole thing is a process. Sounds like go bigger.
A larger B-series machine (not BX) might fit the bill nicely.
I would ... and did.Get the tooth bar.
Yup ... $7,000 will buy a lot of mini-excavator rental time ...Forget the backhoe due to price.
Mini-ex's tend to be much faster - and usually more powerful - than using a backhoe on a tractor.
Yup ...Get roto tiller.
Rototillers come in a couple of flavors: the final drive being either chain-driven or gear-driven. Gear-driven are probably more durable.
King Kutter makes reasonably priced gear-driven tillers and they are often carried by ag chain stores.
I own a 60" King Kutter tiller myself.
If you are planning on doing lots of landscaping and tree/shrub planting - in addition to fence posts - then I'd strongly advise that you consider a post hole digger (PHD) for the 3PH.Maybe rent when post holes are needed.
You can buy the augers (or "drill bits") in various diameters.
The larger augers are very handy for planting shrubs and small trees ... makes it real easy (depending on your soil) to pop a large hole in the ground a couple of foot deep ... in just a couple of minutes.
I have a County Line PHD from Tractor Supply ... they are reasonably priced ... you might even be able to score one on an end-of-season deal.
I have 6", 12" and 24" augers that I use on mine. The 6" and 12" are usually carried at most TSC's ... the 24" had to be ordered ... took about a week. There was also a 30" available that I would have liked to have had ... but it cost nearly as much as the PHD itself. I think the 24" auger bit alone was around $500.
Boxblade or land plane/grading scraper.Then forgot to answer driveway of gravel. That one is 12' wide and 150' long
Either can be used to level any areas that need to be, in addition to maintaining your driveway.
One advantage they have over a Ratchet Rake is that they are mounted on the 3PH ... and therefore the side-to-side angle of the implement can be adjusted independently of the tractors wheels, via the tractor's adjustable side link.
IOW, a box blade or LPGS can be tilted side to side ... something that one cannot do with any FEL-mounted implement.
