Tipping trailer use
/ Tipping trailer use #1
docfoc
Woolage Green
Kubota B7100
I am new owner of a Kubota B7001D 4x4 ( with front loader and rear 3 point hitch) and have bought a tipping trailer for muck. The trailer and tractor both have a quick fit hydraulic connector, however I am not sure how to divert the hydraulic power from 3 point hitch or loader to the trailer.
I have been told to raise the 3 point hitch to max height at which point the hydraulic fluid will be directed to the trailer ram... is this correct as so far it has not worked... am I missing something...
thanks
This is the current set up..
/ Tipping trailer use #2
Can you push in on the middle piece of both quick connects?
What happens if you remove the quick connect and drop the end of the hose in a bucket (do this with the 3 point all the way down)?
I would suspect that there is a problem with one of the quick connects.
Aaron Z
I had wondered if it was the connectors... If I drop it into a bucket with the three point down presumably the fluid will pour out . or will this only happen if it is all the way up... ?
/ Tipping trailer use #4
It shouldn't dump out any fluid until you move the lever to lift the 3 point.
Aaron Z
Thanks Aaron... will give it a go in the morning (10pm here in UK),,cheers
/ Tipping trailer use #6
Need more info.
Where did you plug in the hose for the hyd fluid?
What valve is controlling the fluid to the tipping trailer.
Is the cyl a SA or DA cyl?
/ Tipping trailer use #7
Looks like it's in the relief of the 3-point.
/ Tipping trailer use #8
I am not sure you can obtain the relief fluid as it goes directly to tank.
/ Tipping trailer use #9
Need more info.
That model is setup so that you can tie a SA cylinder in parallel with the 3 point ram, then when you raise the 3 point, it can push fluid into the external ram at the same time.
See: http://www.orangetractortalks.com/forums/showthread.php?t=501 for some discussion on the subject (sadly without working pictures)
Aaron Z
See: Extra hydraulics on B7001? - OrangeTractorTalks - Everything Kubota for some discussion on the subject (sadly without working pictures)
Aaron Z
Problem sorted , I temporarily disconnected the feed back lever from the control arm which meant I could have the control arm on maximum resulting in the fluid being diverted to the tipping trailer... thanks for the advice
/ Tipping trailer use #11
Glad to hear that its working.
Aaron Z
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
Rotomec PHD 300 (A64126)
Rotomec PHD 300...
3012SFL (A61567)
3012SFL (A61567)
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
