Tipping Point on BX23
/ Tipping Point on BX23 #1
TarNFeather
MO
BX23
I just had a pond put in and am trying to get the back of the dam seeded. The steepest part is 22 degrees. Going across it, I have found that when I reach around 12 degrees my inner ear starts telling me, 'LOOK OUT!'. Going straight up and down I get the warning at about 20 degrees. Does anyone have any idea what the tipping point for a BX23 with the following specs might be?
FEL attached and empty.
AG tires.
Foamed front tires and fluid filled back.
300 lb box blade on back.
Thanks.
/ Tipping Point on BX23 #2
Vertical you should have no problem with 25*
I mow horizontal on a 20*+ slope. No loader. No box blade.
Where things can change FAST is with the loader. Raising the loader (or attachments) can change your centre of gravity both quickly and drastically. This doesnt come into play as much vertically, but horizontally, look out.
If your trying to seed, going vertical would be the safest option, particularly if you arent familiar with your machine. A full hopper of fert puts a fair bit of weight up high so keep the 3pt low. Counter it with a bag of fert in the bucket (also kept low). And when i say vertical, i mean VERTICAL. Going at a bias can be almost as bad as purely horizontal if your new.
/ Tipping Point on BX23 #3
I suggest you Google for "tractor tipping video". A specific thing to remember is that many tipovers on hillsides and slopes are not due solely to the degree of the slope, but to going over some irregularity (like dropping a wheel into a divot, or having one wheel go over a mostly-buried rock). :( It is at that moment that the tractor is pushed past the tip point, and over it goes.
Looking at the online videos is instructive and educational. There is one you'll find of an unmanned tractor (remote controlled!) where they test to see what makes it go over. Very cool... a tractor drone! :thumbsup:
-Mitch
/ Tipping Point on BX23 #4
-Mitch
Very good idea!!
/ Tipping Point on BX23 #5
I just had a pond put in and am trying to get the back of the dam seeded. The steepest part is* 22 degrees. Going across it, I have found that when I reach around 12 degrees my inner ear starts telling me, 'LOOK OUT!'. Going straight up and down I get the warning at about 20 degrees. Does anyone have any idea what the tipping point for a BX23 with the following specs might be?
AG tires.
Thanks.
*A 22 degree side slope is way over the limit of 15 degrees.
I'm assuming you're quoting the manual, which I don't happen to have in front of me?
Good info!
I'm assuming you're using a MMM? Are your tires filled? Also, what kind of tractor are you using?
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2022 John Deere 1795 Planter (A63111)
2022 John Deere...
2017 Chevrolet Express 3500 12FT Box Truck w/ Liftgate (A61573)
2017 Chevrolet...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
