Tip for 3pt Mower Maintenance
/ Tip for 3pt Mower Maintenance #1
looch
QC, Canada
CK2620 SE Cab
I just finished a tear-down / repaint of my Buhler/Farm King 3pt mower. I found quite a bit of rust beneath the wheel supports that attach to the deck - metal on metal. I took an old, small nylon chopping board from the kitchen (checked with the boss) and cut some disks using a hole-saw. I inserted them under the supports to raise them slightly off the deck. No vibration and no water gets trapped.
/ Tip for 3pt Mower Maintenance #2
I wonder if you coated that area with some of that truck bed lining stuff would help protect it some more or just hold in moisture and cause more rust?
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
(3) 5 LUG TRAILER DROP AXLES (A64280)
(3) 5 LUG TRAILER...
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
