Tiny timber frame wood shelter
/ Tiny timber frame wood shelter
</font><font color="blue" class="small">( Just have to repeat, nice job. I've always admired that kind of work, but never took the time to learn it. Where in SE Michigan is Riverbend? )</font>
They're in Blissfield. I just went to their site and I didn't see any course offerings. They may not do that anymore.
riverbend timberframe
There are a lot of places to take a class though. Do some internet searching, or get a copy of Fine Homebuilding. They usually have lots of ads in there.
Cliff
/ Tiny timber frame wood shelter #22
Thanks Cliff, they are right in my backyard. I guess it pays to be a little more aware of your surroundings! /forums/images/graemlins/blush.gif
Here's a picture of the finished project as promissed.
Cliff
And one more.
Cliff
/ Tiny timber frame wood shelter #25
I think I'd be real careful sticking my hand in there for firewood. It just might bite, the firewood. A home that nice would be very very hard to leave.
You do very nice work.
/ Tiny timber frame wood shelter #26
I believe that might be the fanciest woodshed I've seen. /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( I believe that might be the fanciest woodshed I've seen. /forums/images/graemlins/wink.gif )</font>
Happy wood makes a happy fire?
Actually, since our neighbors are pretty close, and we are a bit too rural for them already, I felt like I should make something nice for the yard. It turns out that we get enough drop and chop from the trees that, while I take wood from this little shed for the fire because it's dry, I have most of my wood in a big pile further back in the yard where they don't have to look at it.
I've attached a picture of the other outbuilding I built about ten years ago. It's an 8X8 garden shed, but I wanted something that added to the property, not detracted from it.
Cliff
/ Tiny timber frame wood shelter #28
</font><font color="blue" class="small">( It's an 8X8 garden shed )</font>
That's definitely prettier than my 7 x 7 Rubbermade shed. /forums/images/graemlins/wink.gif
/ Tiny timber frame wood shelter #29
Cliff, what kind of wood did you use (and what are the dimensions of the posts)? Did you / would you consider making something like this out of pressure treated 6x6 landscape timbers?
</font><font color="blue" class="small">( Did you / would you consider making something like this out of pressure treated 6x6 landscape timbers? )</font>
Yes/yes
Specifically, I used 6X6s from Menards that were treated to refusal (that is, only on the outside) and the 8 footers were $10 a piece at the time. They were also still a little green (as in wet/new) so the cutting was a bit easier. I set the frame on buried concrete blocks so they don't stay wet. Any wood would have worked. These were cheap and using PT wood seemed like a good idea. Use a mask if you're using a power saw.
If you have any trees on your lot that your dropping anyway, it would be a good opportunity to hone your broadaxing skills and chop them out of tree stock. /forums/images/graemlins/crazy.gif
Cliff
</font><font color="blue" class="small">( I think I'd be real careful sticking my hand in there for firewood. It just might bite, the firewood. A home that nice would be very very hard to leave.
You do very nice work. )</font>
Actually, just after I finished it, an opossum tried to move in, but we have dogs who are loose in the yard. That was a very unhappy opossum unitl it moved out of the yard. I suppose I'm lucky none of the dogs actually got hold of it. Ever look in a opossum's mouth? Yikes.
Also had carpenter bees move in, but we doused them and caulked the holes.
Cliff
One final picture of the Timberframe woodshed. This one, full with the latest splitting I did this fall (Yes, for those who haven't noticed, it's fall.
Cliff
New Holland 675 Manure Spreader (A66408)
New Holland 675...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
Unverferth Field Cultivator (A64127)
Unverferth Field...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2021 Peterbilt 579 (A64127)
2021 Peterbilt 579...
