Tiny timber frame wood shelter
/ Tiny timber frame wood shelter
</font><font color="blue" class="small">( Just have to repeat, nice job. I've always admired that kind of work, but never took the time to learn it. Where in SE Michigan is Riverbend? )</font>
They're in Blissfield. I just went to their site and I didn't see any course offerings. They may not do that anymore.
riverbend timberframe
There are a lot of places to take a class though. Do some internet searching, or get a copy of Fine Homebuilding. They usually have lots of ads in there.
Cliff
/ Tiny timber frame wood shelter #22
Thanks Cliff, they are right in my backyard. I guess it pays to be a little more aware of your surroundings! /forums/images/graemlins/blush.gif
Here's a picture of the finished project as promissed.
Cliff
And one more.
Cliff
/ Tiny timber frame wood shelter #25
I think I'd be real careful sticking my hand in there for firewood. It just might bite, the firewood. A home that nice would be very very hard to leave.
You do very nice work.
/ Tiny timber frame wood shelter #26
I believe that might be the fanciest woodshed I've seen. /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( I believe that might be the fanciest woodshed I've seen. /forums/images/graemlins/wink.gif )</font>
Happy wood makes a happy fire?
Actually, since our neighbors are pretty close, and we are a bit too rural for them already, I felt like I should make something nice for the yard. It turns out that we get enough drop and chop from the trees that, while I take wood from this little shed for the fire because it's dry, I have most of my wood in a big pile further back in the yard where they don't have to look at it.
I've attached a picture of the other outbuilding I built about ten years ago. It's an 8X8 garden shed, but I wanted something that added to the property, not detracted from it.
Cliff
/ Tiny timber frame wood shelter #28
</font><font color="blue" class="small">( It's an 8X8 garden shed )</font>
That's definitely prettier than my 7 x 7 Rubbermade shed. /forums/images/graemlins/wink.gif
/ Tiny timber frame wood shelter #29
Cliff, what kind of wood did you use (and what are the dimensions of the posts)? Did you / would you consider making something like this out of pressure treated 6x6 landscape timbers?
</font><font color="blue" class="small">( Did you / would you consider making something like this out of pressure treated 6x6 landscape timbers? )</font>
Yes/yes
Specifically, I used 6X6s from Menards that were treated to refusal (that is, only on the outside) and the 8 footers were $10 a piece at the time. They were also still a little green (as in wet/new) so the cutting was a bit easier. I set the frame on buried concrete blocks so they don't stay wet. Any wood would have worked. These were cheap and using PT wood seemed like a good idea. Use a mask if you're using a power saw.
If you have any trees on your lot that your dropping anyway, it would be a good opportunity to hone your broadaxing skills and chop them out of tree stock. /forums/images/graemlins/crazy.gif
Cliff
</font><font color="blue" class="small">( I think I'd be real careful sticking my hand in there for firewood. It just might bite, the firewood. A home that nice would be very very hard to leave.
You do very nice work. )</font>
Actually, just after I finished it, an opossum tried to move in, but we have dogs who are loose in the yard. That was a very unhappy opossum unitl it moved out of the yard. I suppose I'm lucky none of the dogs actually got hold of it. Ever look in a opossum's mouth? Yikes.
Also had carpenter bees move in, but we doused them and caulked the holes.
Cliff
One final picture of the Timberframe woodshed. This one, full with the latest splitting I did this fall (Yes, for those who haven't noticed, it's fall.
Cliff
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
3147 (A63117)
3147 (A63117)
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
First Choice 6' 3Pt Finish Mower (A66408)
First Choice 6'...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
