Tiny Tach Rpm's
/ Tiny Tach Rpm's #1
HarleyScooter
Canton, Ohio
Kubota/ BX2230
Tiny Tach Rpm\'s
I just put a Tiny-Tach on my BX 2230, and the readings just do not seem right, it shows a warm Idle of 1280 rpm and a wide open throttle speed of 3400 rpm. What readings are other members getting? I did clean all the paint off the injector line and tighten the clamp securely.
Thanks
HarleyScooter
/ Tiny Tach Rpm's #2
Re: Tiny Tach Rpm\'s
Frank,
I have the BX2230 and my readings are very close to yours. Idle is between 1180 - 1250 and full throttle is 3400.
Hope this helps.
Steve
/ Tiny Tach Rpm's #3
Dead on mine is 1280 3360
There is another thread on this on 13 Aug
/ Tiny Tach Rpm's
Thanks for the reply's. This is my first diesel and I thought the 3400 rpm reading was kind of high, but I did hear Kubota runs this engine at higher rpm's to get the rated HP.
Thanks
/ Tiny Tach Rpm's #5
Now, wait a minute. Are you saying a tiny tach sense lead wrapped around an injection line can sense the fule pressure pulses? this is a bit weird, I thought the T.T. worked on electrical spikes, picked up by inductance, because of the sense wire wrapped around the high voltage lead (spark plug lead). How can it sense fuel pressure spikes, or what is it sensing on a diesel? /forums/images/graemlins/confused.gif
/ Tiny Tach Rpm's #6
It most certainly counts fuel pressure pulses in the injector line. I believe the pick up is some sort of piezo electric device that converts motion to electric pulses similar to the thing that lights BBQ grills
/ Tiny Tach Rpm's #7
Mine's a diesel, so it would have trouble finding a pulse on the plug wires.......... /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
/ Tiny Tach Rpm's #8
That's why the diesel model comes with the fuel line transducer.
Mine just arrived yesterday and will be mounted this weekend!!!
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
John Deere 4320 (A64911)
John Deere 4320...
CAT 988B Final Drive (A68134)
CAT 988B Final...
Circular Alley CC Hydraulic Cattle Chute (A64912)
Circular Alley CC...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
TIRE RACK WITH DIFFERENT SIZE TIRES/WHEELS (A67714)
TIRE RACK WITH...
