Time to check out the generator.
   / Time to check out the generator. #81
I grew up in California, the Bay Area. I moved to the Sierra in 1977. My wife got pregnant so we moved lower down to Tuolumne City. We would get a notice with our water bill that the water we were paying dearly for was unfit for human consumption. We were drinking PG&E "Ditch Water". The ditch water was from a flume originally used for hydraulic mining of gold in the 1800s. PG&E never bothered to cover the miles long flume and ditch system so we got bad and expensive water. No wonder we left in 1980 and ended up in WA State. PG&E has not changed in all these years. They couldn't care less about their customers or the fires and deaths they have caused. It seems to me they should be disbanded.
Eric
Yup. Haven't changed much.
   / Time to check out the generator. #82
When we built our new house, I had a whole house generator installed and will never be without one again. It does a 10 minute self test run every Monday at 10:00 a.m.
Old remodeled 120 yar old shack... The house has it's own propane fired 20KW Generac and the shop and barns have a 35KW John Deere powered diesel fired Generac that makes 110-220-3 and 440 and it runs off my 500 gallon farm diesel tank and it has it's own 150 gallon tank underneath the unit as well. Both of them exercise weekly and both are hard wired (of course) through a vacuum breaker breakout switch that breaks utility power before they assume the load. Both are over 15 years old and other than routine service, both run like tops. When we lose the utility (which is often out here), the units assume the load in 45 seconds.
Glad I bought them when I did because the cost of the bigger units is outta sight today. Priced a new 20 KW Generac the other day and they are 15 grand not including install. Didn't even bother pricing the diesel unit, probably scary high.
Finally, glad I don't live in Kalifornia and if I did, I'd be moving east.
Next time I start one of my pre 4 diesel powered M9's and it blows off a puff of black sooty smoke, I'll be thinking about all of you out there...lol
   / Time to check out the generator. #83
Eric
Sounds like Erin Brockovich could have stung a little harder.
https://en.wikipedia.org/wiki/Erin_Brockovich
   / Time to check out the generator. #84
PGE notified the Hospital that a PSPS may be in the future as early as noon Thursday.
This is when the utility shuts down the grid which may cover most of Northern California as a measure to prevent a repeat of some of the massive wildfires in weather events...
And this is the same grid California wants you to use to charge your electric car! :rolleyes:
   / Time to check out the generator. #85
Yep and at some of the highest rates in the country…
I bet I see dollar a kWh someday in the future for peak use.
   / Time to check out the generator. #86
Any home backup generator is only as good as the fuel supply you have on hand or can get delivered reliably.
Propane is the most common but as posted earlier, requires a very large storage tank and could be difficult to resupply during an extended outage.
Gasoline has similar issues with the addition of shelf life and safety concerns. Before I went diesel, I used to fuel my gas genny by siphoning fuel from my vehicles. It often got messy and there is always the health issue.
IMO, if you heat with fuel oil, the best option is a diesel generator. I have a 1000 gal tank and even half full, it will supply my 11KW genny for a month if necessary. Yes, there is always the possibility of gelling and bacteria contamination, but I've been using it in my furnace and tractors for decades and have never had this issue.
   / Time to check out the generator. #87
When I was evaluating the fuel choice, there were factors on each side. Getting a propane refill post-earthquake was a major minus. But the ability to bury a 500-1000 gallon propane tank was a plus; you can store the fuel forever. I was told such can survive a wildfire. And any contamination was in the liquid; you burn the vapor.
Smaller generators run off of 20# "BBQ bottles" tanks.
Storing a quantity of Diesel has many issues, including insurance. You will never get a permit in NoCal to bury a Diesel tank unless you spend $$$ and years. You have to "groom" the fuel to kill the bugs, circulate it, etc. But the engine has no ignition system to fail.
We decided on propane, with also a smaller PTO generator off of the Kubota. As it happened, the client changed jobs and moved out of state before building the house.
BTW, don't confuse #2 Heating Oil with Diesel. #2 has a lower Cetane rating and was also hard on injector pumps. You can likely get away with using it at the expense of engine life.
   / Time to check out the generator. #88
Propane might survive a wildfire if it is in a well cleared area, and preferably buried. The Paradise, CA fire had lots of reports of propane tanks exploding. (The state now requires 10' clearance to dirt around the tanks) Defensible Space | CAL FIRE
Our county wants 20'.
Yes, I wouldn't want to try to get a permit for 1,000 gallon buried underground storage tank, especially as I know that there is a volume cutoff (55gallons underground) that gets you into larger regulations. I know that there is some exemption for farms and ranches, but I don't recall the limits.
I think your point on oil fuel is well taken. #2 heating oil and diesel may or may not be similar depending on the locale, but #2 heating oil is almost certainly short of lubricity enhancers and other additives diesel engines benefit from.
All the best,
Peter
   / Time to check out the generator. #89
All the best,
Peter
Around here #2 heating oil and #2 off road red dyed diesel come out of the same truck and have for several years.
   / Time to check out the generator. #90
Thats weird…. Here #1 diesel and red dyed diesel are the same. #2 heating is different tank. The red dyed diesel simply is regular diesel with dye added.
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A57453)
2004 MCI D4500...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2014 Ford F-550 (A55973)
2014 Ford F-550...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
