Time to check out the generator.
   / Time to check out the generator. #91
Thats weird…. Here #1 diesel and red dyed diesel are the same. #2 heating is different tank. The red dyed diesel simply is regular diesel with dye added.
I do not think it is weird; I do think that what passes for home heating oil varies by location, just as gasoline blends vary by geography, brand, and season. I would point out that it gets just a wee bit colder where @grsthegreat is than where @LouNY is and that may have something to do with it.
Here, our diesel changes from #2 to something closer to #1 during the winter. I know of a few folks that took their vehicles from down here in the relative warmth with a tank of summer diesel up into the snow for some winter fun and had gelling issues. I think that folks who live in cold winter areas with diesels are more aware of cold weather gelling. Apparently, a few Californians were less aware...
As an aside, the hydro treated renewable diesel has a gel point as low as -40F.
All the best,
Peter
   / Time to check out the generator. #92
Around here #2 heating oil and #2 off road red dyed diesel come out of the same truck and have for several years.
Same here, no difference between the two except the dye.
SR
   / Time to check out the generator. #93
In my area of Tn. if I would ask for #1 diesel it would more than likely be a mix of #2 diesel and kerosene. Probably 50/50 mix for winter use. No difference between red diesel and gas station pump diesel except dye for tax purpose.
   / Time to check out the generator. #94
BTW, don't confuse #2 Heating Oil with Diesel. #2 has a lower Cetane rating and was also hard on injector pumps.
It’s all ultra low sulfur now.
No confusion on our part
The spec for diesel cetane means #2 may, or may not be identical. Economies of scale means a lot of diesel is the same as #2.
Seems recently, it’s cheaper for them to make a single product that meets the diesel spec
   / Time to check out the generator. #95
Much of #2 is refined the previous summer. Here's why: When you refine crude you get light ends [gasoline] & distillates [Kero, #2 Heat, etc.] The refinery has some control of the ratio, but it'd never be 100:0; let's just say it's 60/40 or 40/60. So in the summer [driving season...] it's 60% gasoline/40% distillates. The latter is tanked all summer for winter use. In the winter, the 40% gasoline is what's tanked until summer. Those specific 80,000 bbl tanks were flipped back and forth every spring & fall.
Now as for brand, I got news for you. Companies trade all products back and forth. If Acme has 100,000 bbls of Regular in NJ, and Colorado-based Zebra needs it in OH, no problem. They may have too much Diesel and ....
The only exception was back then, Sunoco regular was 86, not 87 octane; no one would buy Sunoco Regular. This was because Sunoco promoted multiple octanes; they were created at the gas station pump by mixing the 86&93 in different ratios. Since then fuel injection has taken over and the standards for gas have been tightened. [Not octane, but other issues.]
Mountain areas "summer gas" was tweaked to avoid vapor lock, but I wonder if it still is, given the switch to fuel injection and in-tank pumps that push vs pull fuel.
   / Time to check out the generator. #96
Around here summer gas is tweaked to lower the vapor pressure and winter gas has additional oxygenates. That's pretty much the case in any area in the US under air quality regulations.
   / Time to check out the generator. #97
I suppose there will be no end to the debate over the difference between home heating oil & diesel. The fact remains that I have been using heating oil in my diesel engines for 45 years now and have never had any issues.
The fuel oil I get here is an Exon / Mobile product and the dealer says the only difference is the color. The climate here in PA isn't extreme though, so I can't pass judgement on it's use or composition in other parts of the country.
   / Time to check out the generator. #98
Yes, I wouldn't want to try to get a permit for 1,000 gallon buried underground storage tank, especially as I know that there is a volume cutoff (55gallons underground) that gets you into larger regulations.
I was just looking at the APSA and it exempts propane.
   / Time to check out the generator. #99
Yes, you are right it does exempt propane. I think that the intent of the act is really focused materials that could leak and cause environmental issues. So, a large buried propane tank would be pretty safe in the face of wildfire, with no permits needed.
All the best,
Peter
   / Time to check out the generator. #100
A question on the warmup time for Diesel powered generators.
First, the background:
When I last hooked up my PTO generator to test, I decided I was getting too old to deal with the hassle. Taking the existing implement off the tractor and attaching the genny for a power outage that may only last a short period of time, seemed like more effort than it was worth. Losing use of the tractor for other purposes during longer outages, and having to refuel it outdoors during bad weather, was also a negative.
Earlier this month, I sold the PTO genny, which had served me well for many years, and bought a Kubota GL11000 standalone diesel generator. I'm in the process of installing it in the back of one of the barns with an automatic transfer switch. It's been a learning experience so far and not without issues.
The question:
The generator has the OEM automatic transfer option, which starts the engine 20 seconds after the power goes out. 10 seconds later, the transfer relay activates, and generator power is restored to the house.
This is what I don't understand: The manual says to warm the engine for 5 to 20 minutes, depending on temperature, before applying load. Otherwise engine damage could occur. The factory installed transfer switch applies the load just 10 seconds after the engine starts. Why would the engineers design a transfer switch that could damage the engine?
This short delay between outage and switch to generator power is common for propane and gasoline powered systems but does not seem appropriate for diesel. The manuals for all the diesel tractors I've owned say to warm the engine before applying load.
Yet I see many diesel powered systems that ignore the warmup period. People frequently jump in their diesel pickups, start them and drive away. The twin Cummins diesel powered generators in the basement of the building where I used to work, transfer from commercial to generator power in less than 5 seconds. What gives? Is there something magic about diesel engines used to power generators?
Forklift Self Dumping Hopper (A56860)
Forklift Self...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
1660 (A59213)
1660 (A59213)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A57453)
2008 Hino 268...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
