Time for 50 hour maintenance
/ Time for 50 hour maintenance #1
pjwbx2230
Coshocton, OH
kubota bx2230
Any helpful advice? You folks have helped this first time "real" tractor owner through some previous minor crises. Got everything back together and the rear bagger on- the bx cuts like a dream- yard looks great. EEven with the front end loader on, the tractor is remarkable maneuverable- no need for trimming, other than weed eating- love the bx and want to keep her happy. Any helpful advice to make the 50 hour service go more easily would be greatly appreciated. Thanks in advance.
/ Time for 50 hour maintenance #2
Taken from Kubota.com parts section:
SERIES BX
MODEL BX2230D
ENGINE MODEL D902-E-BX
DECK MODEL RCK60B-22BX
Owner's Manual K2571-71211
Parts Manual 97898-41450
Maintenance Chart 97897-51430
Engine Manual N/A
Shop Manual 97897-13090
Fuel TBD
Cooling TBD
Crankcase TBD
Transmission TBD
Hydraulic TBD
Axle TBD
Engine Oil SEE OPERATOR'S MNL
Hydraulic Oil SEE OPERATOR'S MNL
Transmission Oil SEE OPERATOR'S MNL
Fuel Type D
Air Filter Outer N/A
Air Filter Inner/Element N/A
Engine Oil Filter 15853-32430
Engine Oil Filter #2 N/A
Engine Oil Gasket N/A
Drive Belt 15881-97010
Auxillary Belt TBD
Mower PTO Belt TBD
Hydraulic Oil Filter K2561-36990
Oil Filter Gasket N/A
Hydraulic Suction Filter 66021-36390
Suction Filter Gasket 04811-10300
Hydraulic Return Filter TBD
Return Filter Gasket TBD
HST Filter (if applicable) N/A
HST Filter Gasket N/A
Fuel Filter Element 12581-43012
Fuel Filter Gasket N/A
Battery 70000-00148
Starter 19269-63010
Alternator 15531-64016
Block Heater (Standard Models use 70000-00298)(Models with dealer installed optional Cab use 70000-02968)
Blade (Quantity) K5371-99040 (3)
Kit Blade K5371-97520
Blade Belt (Quantity) N/A
Deck V-Belt K5763-34710
Engine Oil
70000-10000 1 QUART 15W-40
70000-10000 1 GAL 15W-40
70000-10002 2.5 GAL 15W-40
70000-10005 5 GAL 15W-40
70000-10055 55 GAL 15W-40
70000-10100 1 QT SAE 30
70000-10101 1 GAL SAE 30
70000-10105 5 GAL SAE 30
70000-10155 55 GAL SAE 30
70000-10200 1 QT 10W-30
70000-10201 1 GAL 10W-30
70000-10202 2.5 GAL 10W-30
70000-10205 5 GAL 10W-30
70000-10255 55 GAL 10W-30
Gear Oil
70000-10500 1 QT GEAR 80W-90
70000-10502 2.5 GAL GEAR 80W-90
70000-10520 GEAR 80W-90 120#
70000-10535 GEAR 80W-90 35#
70000-73435 GEAR 85W-140 35#
Hydraulic Oil
70000-10602 2.5 GAL A/W 46 HYD.
70000-10605 5 GAL.A/W 46 HYD.
70000-10655 55 GAL A/W 46 HYD.
Grease
70000-10701 14OZ,POLYUREA GREASE
70000-10735 35LB.,POLYUREA GRS.,
70000-10401 Grease, Moly Lithium Complex #2
Transmission/Hydraulic Fluid
70000-20000 1 QT UDT FLUID
70000-20001 1 GAL UDT FLUID
70000-20002 2.5 GAL UDT FLUID
70000-20005 5 GAL UDT FLUID
70000-20055 55 GAL UDT FLUID
70000-40100 1 QT SUPER UDT FLUID
70000-40101 1 GAL SUPER UDT
70000-40102 2.5 GAL SUPER UDT
70000-40105 5 GAL SUPER UDT
70000-40155 55 GAL SUPER UDT
Thanks. Already have figured out the capacities, etc. Have my Super UDT waiting. Any advice on oil (used to gasoline engines. Also, someone mentioned a square, rectangular drain bucket bought at TSC, I think? ANyone have any pointers to make this effort go more smoothly?
/ Time for 50 hour maintenance #4
Take a look at this thread, about 3/4 down on the page is service on a BX2200 thread.
web page
Put plastic on the floor, I did my 300 hour service a few weeks ago and I forgot to read my own post. /forums/images/graemlins/mad.gif
Thanks for the link. Just went to TSC and got an extra funnel (can never have too many), gear oil (figured I might as well change the gear oil in the MMM even though it does not have 50 hours yet), and oil. Already had the Super UDT (liquid gold) and filters. THe guy at TSC recommended Rotella T 15-40 oil- has the proper API rating and says he uses it in all of his tractors (he has a New Holland) and even his big rig. I bought it on his rec, fully realizing that Kubota calls for 10- 30 or 10-40. Will this oil work? If not, what should I return it for?
Can someone please answer my post regarding the Rotella T motor Oil.. It would be appreciated. I note, on the spec page, provide above, 15-40 oil is listed, so I assume it will be okay.
Thanks, Tom, and go Sox!!! /forums/images/graemlins/grin.gif
/ Time for 50 hour maintenance #9
Another tip:
Lowes sells a sort of squared-off, low, black plastic bucket for $5. It fits EXACTLY between the rear wheels of the BX and will catch all the SUDT from the drain and the filter.
RDnT
2022 EZ-GO ELITE...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
KMC 3386 (A64119)
KMC 3386 (A64119)
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
