Timber Frame vs Pre-Engineered Steel?
/ Timber Frame vs Pre-Engineered Steel? #21
I've done both.
My shop is a 24 x 42 ft steel building with 12-ft walls, two 10x10 ft rollup doors, one man door, one window, 26 ga steel panels. It's on a concrete slab 6" thick, 4000 psi concrete, #4 rebar on 24" centers. Cost: $16K for the building installed by the contractor, $7K for the slab poured professionally by a contractor (in June 2005).
I built a 20 x 28 ft wood pole frame building with sloping roof (11 ft in front, 10 ft in back). The posts are set on concrete footings and are attached with Simpson post anchors. Siding and roof are 29 ga steel R-panel. Cost: materials about $4K and a month of my time (I'm old and I work slow) in 2009.
Shop-1.JPGShop-2.JPGEquip shed finished-1 (Medium).JPGEquip shed finished-1.JPG
Good luck
Gravity Box (A65640)
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
20ft Driveway Gates (A65579)
20ft Driveway...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
