Timber Frame Build - Round 2
   / Timber Frame Build - Round 2 #51
That staining sure was quick. Glad you where able to find a cleaner. Will this be an ongoing issue?
   / Timber Frame Build - Round 2 #52
TBN is the first and only online "forum" I've ever participated in. Is there something similar for timber framing?
It will be a late summer/early fall issue however the sealer should prevent the permanant staining. A water spray nozzel or light pressure washing should take care of it now. Some coffee in the mornings with my .22 rifle would also help the issue. Its amazing how fast those squirrels can de-shell several walnuts.
Block work for stone columns was done yesterday. Stonework was started this morning. I haven't made it by yet to see how it's looking.
Going to try to get by there later this evening.
2017-09-10_05-46-48
Stone on 2 of the 6 columns was finished yesterday. The remaining 4 will be completed next weekend as my stone masons are doing this work as a side job. Need to figure out what I'm going to use for caps.
2017-09-11_08-13-13
   / Timber Frame Build - Round 2 #57
Sure looks professional in every way possible. Did you design all this yourself?
Thanks Eddie and yes. Same as the home build in that I had a pretty good visual in my mind of the finished product. I don't plan to do near as much work myself on this project though. I'll probably leave the landscaping design to the pros as well.
   / Timber Frame Build - Round 2 #59
Eddie wow! That is impressive. love the floor love the floor love the floor!
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
