Tilt Trailers - Questions
/ Tilt Trailers - Questions #21
I have a Cam tilt deck too, deck is split, IIRC tilt is 16' with a 3' section in front that is fixed. Can fit my Kubota L3010 w/loader and rake, or brush hog. Also perfect for my KH-91 excavator. If you use your trailer on construction sites w/loose dirt the dropleg ramps can be a pain. Sometimes, if you're not on a level, once you are loaded, and the trailer squats, the dropleg will hit the ground and keep you from flipping the ramp up, or you can't get them down when you go to unload. My 79yr old helper (Dad) doesn't miss the ramps at all.
/ Tilt Trailers - Questions #23
A split deck allows you to load implements or other items on the trailer and still be able to tilt it to load/unload the tractor or equipment.
/ Tilt Trailers - Questions #24
A split deck would also move the axles back farther
/ Tilt Trailers - Questions #25
Anyone have experience wit "blackwood decking"?
Saddle Tanks (A65640)
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2022 EZ-GO ELITE...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
