tilt drifting
/ tilt drifting #1
coqui
toolcat 5600
2006 tool cat. tilt slowly drifts down with engine off or running. cylinder seals replaced twice shows no damage. Is this a spool problem or could it be relief valve or spool lock valve. anyone replaced either the spool or valves and had success?? thanks coqui
/ tilt drifting #2
Mine does the same thing, annoying when mowing. I blame it on the tilt cylinder which shows a small leak.
/ tilt drifting #3
Lower the loader so there is no weight on the tilt cylinder. Disconnect the rod end hose for tilt from the valve and cap it off so there are no external leaks. Raise the loader so their is now weight trying to dump the bucket - extend the cylinders. If bucket tilts the cylinders are leaking internally. If bucket does not move then leaking thru the valve.
/ tilt drifting
Done that and leaking through the valve. question pulled spool it looks ok or could it be a relief or lock valve problem.
/ tilt drifting #5
Does that valve have work port relief valves if yes then possible the work port relief is leaking. Same for any load holding valve.
Spool could possibly not be centering properly which could allow some extra leakage from work port to tank.
Have you measured the cylinder movement vs time and then calculated the leakage? Reason for asking is all spool valves leak…question becomes what is normal and acceptable.
/ tilt drifting
Thanks. valve has 3 load locks and a work port relief plus 2 othe4 port reliefs. You can push on the bucket by hand and it moves steadily down. Maybe I can switch the load locks and isolate the problem further.
/ tilt drifting
Switched load holding valves, lift and bed cylinde4s no drift. Tilt still falliny
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2019 FAE UMLV SSL- 150VT HYD MULCHING HEAD (A65053)
2019 FAE UMLV SSL-...
JOHN DEERE CAT IV / III QUICK HITCH (A64278)
JOHN DEERE CAT IV...
UNUSED FUTURE D680 HYD PILE HAMMER (A65055)
UNUSED FUTURE D680...
2004 Caterpillar 315C Hydraulic Excavator (A64194)
2004 Caterpillar...
