Tiller repair help
/ Tiller repair help #1
Anonymous Poster
Epic Contributor
I need some advice on repairing my tiller. I just received my NH TC18 and the guy "threw-in" a Howard 48'' used tiller with it for next to nothing, as-is. Well, I was using it in the garden and all of a sudden, the tiller gearbox starting jumping all over the place. What happened is, all but one of the four bolts that mount the gearbox were missing and the one that was there, snapped off. I removed the gearbox tonight and drilled and tapped the three remaining holes. The snapped off bolt will not come out with an easy-out, as it's an extremely hard bolt. My question is, when I get it all back together with the three mounting bolts, should I weld the darn gearbox right to the frame? The tiller has probably a few good years left in it if everything goes right. Would welding it in place hurt anything? I will still be able to remove the side cover of the gearbox for servicing, I just won't be able to remove the gearbox itself. What do you all think?
Thank you,
Dave
/ Tiller repair help #2
I'd take it to a machine shop and let them get the bolt out. If nothing else a shop with an EDM machine can destroy the bolt in place without damaging the gear box. Try to get a guaranteed cost up front. When you reinstall the gearbox use grade 8 bolts and use loctite on the threads. You get a lot of shock and vibration operating a tiller. That may have started the problem.
While you're working on the tiller check out everything. Howard makes a good unit. If it's repaired properly, you may never need another tiller.
/ Tiller repair help #3
Can you drill the rest of the bolt out and retap the threads ?
/ Tiller repair help #4
I really do not like saying this but Weld it and use it up.
/ Tiller repair help #5
Are u handy w/ a welder?
Take a smaller nut and set on top of broken off bolt.
Take a small (3/32 or 1/8) rod and weld thru hole in nut to the top of broken bolt.
U can wrap a piece of paper around the rod to keep it from striking on the side of nut.
The heat of welding the nut on will also loosen the bolt some.
/ Tiller repair help #6
You can drill the broken bolt out using a Malford Tool Co. Hi-Roc solid carbide drill bit. You can buy individual ones from Enco-- www.usenco.com. It's a lot cheaper than using an EDM (diesinker). I own a machine shop and we drill dies all the time with these drills to remove broken bolts, etc. Or you can weld it and run it till it pukes. The problem with welding is that the gearbox is probably cast, versus the structual frame. It will be hard to get a good bond between the two and you might destroy the gearbox.
/ Tiller repair help #7
<font color="blue"> The problem with welding is that the gearbox is probably cast, versus the structual frame. It will be hard to get a good bond between the two and you might destroy the gearbox. </font>
Even worse, the gearbox could be cast aluminum vs the tiller which is likely steel. It aint easy (near impossible) to weld aluminum to steel.
The Howard tiller isn't a throw away. Fix it right & enjoy it for years to come. Even if you have to throw a couple hundred bucks at it, you'd have paid $1,500 + for a new one. Around here (Mass / NH) you can get machine shop labor at about $50 an hour. Don't suspect it would be any more expensive than that in the Finger Lakes.
Suggest getting in touch with the manufacturer Howard Rotovator They should be able to send you an owners manual and offer advice as to what else to check over on the machine.
Good luck & happy gardening
/ Tiller repair help #8
Hazmat:
Seeing as I am still in front of the computer, I looked up the cost of Hi-Roc drills. 1/4"- $12.29, 1/2" - $21.17 with sizes in between. I'd drill the bolt and threads out going to the major diameter of the thread. Then re-tap the hole the next larger size. I'm sure that there is enough material in the casting to do that. Hi-Roc's are really neat, you can drill glass with them.
With Hi-Roc's, you need plenty of coolant at all times as well as a steady pressure on the drill. They work really well in a hand drill motor. I have a friend who is a diesel mechanic and he regularly drills out exhaust studs on Caterpillar engines. Seems as though Cat's are prone to breaking exhaust studs and the studs become brittle with the heat and cool cycles of the engine. He would go through HSS bits like water so I got him a couple of Hi-Roc's. What a happy camper. Remember though, you have to sharpen carbide on a silicon (green) wheel, a regular grinding wheel will not work.
/ Tiller repair help #9
Not bad prices. I assume that they work better in a drill press than a hand drill? He should be able to get the gearbox in a drill press.
/ Tiller repair help #10
They do work better in a drill press, but a hand drill motor works too. You just have to keep the bore flooded with coolant, be it oil or a water based coolant. I use Valenite VT700 synthetic in my machines so if I use one in a hand drill, I put some in a spritzer bottle and use that to keep the bit lubricated.
</font><font color="blue" class="small">( You can drill the broken bolt out using a Malford Tool Co. Hi-Roc solid carbide drill bit. You can buy individual ones from Enco-- www.usenco.com. )</font>
<font color="red"> </font> Good advice as usual. The url is "www.use-enco.com" though
/ Tiller repair help #12
I think any tiller that hasn't been maintained would end up in the same condition. For 3pt attachments.. I believe a tiller is the worst as far as vibration.. even w/ locknuts.. on my NH 72" tiller.. I have to tighten or replace bolts(lost) every season. Last Sat. I was making a second pass on a 1 acre plot for sweet corn.. l looked around in time to see a bolt & nut falling out.. I shut everything down.. put that one back in.. checked all the rest. This happed even after I had tightened & checked the bolts before I started. I can sometimes use the corner of a chisal to try to get sheared off bolts to unscrew.. putting the chisal edge on the outter rim of the sheared bolt.. and tapping w/ a hammer in a counter clockwise direction.. rusted?.. use some WD40 first. I love getting equipment for less.. I just picked up a shed-kept JD 2 row planter from my farm neighbor down the street.. $300 and he still had some sweetcorn seeds in the hoppers from last season.. he just said.. I'll take the first picking. I'm headed back.. to get a double bottom plow for $200.
/ Tiller repair help #13
I apologize for the bad website listing, you are right.
When I offer assistance on this site, it comes from my personal experience or my partners' experience. There is a whole world of specialized tools and procedures that can make so many things easy.
It's like people ask me why I have a plasma cutter versus using a gas axe and I tell them I have the gas axe but the plasma torch is easier and quicker.
Well, I was able to repair the tiller myself. I drilled and tapped the holes out from 3/8 (original) to 1/2 X 20tpi. I removed and replaced some of the old hardware on the tiller at the same time, greased it all up and now I'm back in business. I am going to take the advice on getting the manual for Howard. The tiller is offsetable and has some adjustments on it. I don't think it is set up quite perfect yet, I think the manual will help with that. Overall the thing is not in too bad of shape now that I have cleaned it up a little. I think maybe this winter I'll disassemble my mower and tiller and sandblast them and re-paint. I think a nice BLUE color would suit just fine. LOL. Thanx for all the help.
Dave
/ Tiller repair help #15
Hi-Roc drills also drill armor plate, so if you need some extra money you can start drilling safes................ /forums/images/graemlins/smirk.gif
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
LOOK! (A63109)
LOOK! (A63109)
iDrive TDS-2010H...
