Tiller Tiller Question
/ Tiller Question #1
amitysanimal
Carmel, ME
Kubota B7100
I picked up a heavy duty Bolens tiller, its was made to run off the front of the Bolens motor via pulley that ran down to a driveshaft that ran to the tiller on back. The problem is it turns CCW and my Kubota B7100 turns CW.
My question is would it work ok if I reversed the tines and had the tiller spin backwards? The tines will be quick and easy to reverse. I know it would push the dirt forward, but will that create a problem? I have been looking into trying to mount a small transmission in reverse gear to change the direction, but that would stick the tiller out behind the tractor quite aways.
Also, would the PTO shaft need to have a slide on it or could it be a solid shaft?
/ Tiller Question #2
If the tiller is mounted on three point hitch the PTO will have to slide and be sized in length for the range of the lift arc.:D
The reverse rotation may work if the tractor has enough HP to pull the the reverse rotation tiller. :confused::confused:
/ Tiller Question
The guy I bought it from told me he used it on a small Bolens with a Briggs engine on it so I would hope my 16hp 3 cyl diesel will run it ok.
Thank You for your reply,
Cleve
MF GC2300 fel replaced
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
John Deere 8330 Tractor (A64047)
John Deere 8330...
2019 John Deere R-4038 (A63118)
2019 John Deere...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2003 KAUFMAN 29' GOOSENECK TRAILER (A63290)
2003 KAUFMAN 29'...
