Tiller Tiller Question
/ Tiller Question #1
amitysanimal
Carmel, ME
Kubota B7100
I picked up a heavy duty Bolens tiller, its was made to run off the front of the Bolens motor via pulley that ran down to a driveshaft that ran to the tiller on back. The problem is it turns CCW and my Kubota B7100 turns CW.
My question is would it work ok if I reversed the tines and had the tiller spin backwards? The tines will be quick and easy to reverse. I know it would push the dirt forward, but will that create a problem? I have been looking into trying to mount a small transmission in reverse gear to change the direction, but that would stick the tiller out behind the tractor quite aways.
Also, would the PTO shaft need to have a slide on it or could it be a solid shaft?
/ Tiller Question #2
If the tiller is mounted on three point hitch the PTO will have to slide and be sized in length for the range of the lift arc.:D
The reverse rotation may work if the tractor has enough HP to pull the the reverse rotation tiller. :confused::confused:
/ Tiller Question
The guy I bought it from told me he used it on a small Bolens with a Briggs engine on it so I would hope my 16hp 3 cyl diesel will run it ok.
Thank You for your reply,
Cleve
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
LOT OF MOWER BLADES (A63745)
LOT OF MOWER...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
iDrive TDS-2010H...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
