Tiller Tiller or Disk harrow?
   / Tiller or Disk harrow? #1
froggy
Cooke County, Texas
JD4320 with TNT, electric diverter, cruise control and air suspension seat.
Have been looking at purchasing a tiller or disk harrow (either 3 point or drawn) to put in fire breaks and a garden, but have not decided which is the best way to go. This item will be used on a 50hp pto tractor. Would appreciate any comments on which is the best way to go.
   / Tiller or Disk harrow? #2
It depends.
Or did you want more detail that that?
The disk will be probably better at the fire breaks, provided you get one that is HEAVY. Or at least one that you can add a lot of weight to. The tiller will be way better at the garden. Unless you are doing a couple acres of garden? If you go with the disk, you may want to get a 3 bottom plow too and turn the breaks over, break the roots up, etc before you disk.
If you are buying new, they are both similarly priced. Used disks are fairly easy to find and don't usually cost too much to spruce up. I would guess you can pull a 7 1/2' or 8' disk or up to a 84" tiller.
A cheap way would be to get a used disk and bottom plow and a used rice tiller from the grey market importers. Then you have fewer compromises.
jb
   / Tiller or Disk harrow? #3
I'd go for a plow and disc setup for firebreaks for economy sake. This will also work on the garden depending on size.:D
The disc needs to be a model that can take some weight and make the tractor grunt to do any good.:D
If money is readily available the tiller would be my option.:D
The garden area would be approximately 50' by 50'. 2 individual fire breaks would be 800' by 15'. The land consists of mainly silty clay.
   / Tiller or Disk harrow? #5
What's your budget?
For my little 17hp (pto) Kubota B7510HST I have a used 4-ft Yanmar RS-1200 tiller ($300 from my local grey market tractor guy) for the garden and landscape work. For my 38hp (pto) MF-135 diesel I have a 7-ft Ferguson tandem disc ($200 used) for things like firebrakes, hayfield tilling, etc.
Shop around in the used market if your budget is tight.
Figured on spending around $3,000.00.
   / Tiller or Disk harrow? #7
froggy,
Did you make a decision yet? I'm on the same fence right now... I'm leaning more toward the tiller.
Thanks,
KevinG
Yes, I'm going with a Landpride disk harrow. Will be easier to do firebreaks, etc.
   / Tiller or Disk harrow? #9
I've put a few hours on the tractor with the 3pt. disc harrow now and really like the job it does. I spent an hour this morning working an area about 100' x 75' for a friend so he could plant grass. His yard was un-even and had poor grass coverage. I started with the disk cutting aggressively by shortening the top link. After one pass like that, I lengthened the top link so the disk was level or maybe even a hair lower in the back and worked the ground again cutting very shallow. This made for a powder smooth finish; I was more than impressed.
My disc is weighs about 700 lbs. You should be pleased with "Land pride"
   / Tiller or Disk harrow? #10
From a newbie get disc, subsoiler vs tiller..........I would love a tiller but I think best buy for the buck is disk and subsoiler. I would not buy Tufline....see my post.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2022 Kubota B2601 (A50120)
2022 Kubota B2601...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2004 John Deere 7520 (A50120)
2004 John Deere...
