Tiller tiller for Super A
/ tiller for Super A #1
Walter Bostic
Sneads Ferry, nc
Farmall Suiper A
Would someone suggest a suitable tiller for a Farmall Super A tractor? I own a 1950's model with 3 point hitch.
/ tiller for Super A #3
The hardest part might be hooking a 3 point mounted tiller to your tractor as (if memory serves correctly) the PTO shaft on the tractor is offset to the left side of the machine inline with the engine and trans. I don't think it will work.
/ tiller for Super A #4
Just offset the tiller to get the pto alinement you need...
That will put the tiller over to cover that sides tire track too, so it works out just fine.
SR
I was looking at a 4 foot wide. My soil is sandy (Eastern NC) and has been farmed for many years. Do you think the 4 foot filler would work. I do not think hooking it up would be an issue. I now use a bush hog with the tractor.
/ tiller for Super A #6
I think a 48" will be fine, as long as you make sure the pto shaft is long enough... I think the pto will be higher than on a modern tractor so make sure you have a long enough pto shaft...
I have both, an A and also a 140, but I've never run a tiller on either one...
SR
/ tiller for Super A #7
Will a Super A have a slow enough ground speed?
/ tiller for Super A #8
It should be fine, as he said he has sand and the ground has been worked in the past. Most folks til at too slow of a speed anyway, destroying their soil structure!
Also, the A does have a 4 speed tranny...
SR
A used equipment shop salesman told me my tractor was to fast, but another mechanic told me it would be OK. I am kinda confused. Why can't I till the same ground two times if it does not do the job on the first pass. That is what I do with the disc.
/ tiller for Super A #10
SR
I agree that most people over till and destroy the soil structure, rarely do I see anyone but myself use the higher ground speeds in my locale.
That said, with only 16 hp. at the pto. and 2.3 mph in 1st gear the engine may have a hard time with a 48" tiller.
/ tiller for Super A #11
SR
I'm worried about stalling the engine because ground speed is too fast.
/ tiller for Super A #12
If the ground speed is too fast, the tiller can't dig-in to bog the engine down. It will float/bounce on top of the ground and try to push you faster.
/ tiller for Super A #13
You can, and in most cases, SHOULD! Instead of crawling along pounding the soil to death!
SR
Just got back so, sorry I am late responding. Looks like I am back where I started. I do not want to have to purchase a tiller to determine if it will work on the tractor. Does anyone have a super A with a 4ft tiller?
/ tiller for Super A #15
Almost all of my custom tilling is at about 2.5mph and one of my tillers is a 42" Howard, that I run with 12.5 pto hp tinker toy tractor... It does just fine, so I don't see a super A having trouble with a 48" tiller, in sand no less and sand is easy to till!...
SR
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
2014 F-150 STX (A56438)
2014 F-150 STX...
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2022 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2022 Posi Track...
