Tiller for B2410
/ Tiller for B2410 #1
KDL
West Virginia
B2410 Bi-speed
Hey guys let me get your input on a rotary tiller for my B2410. My dealer is suggesting a Muratori 42" for $1000. He says it is easier to maneuver than the 50" for $1100. He has both in stock. *** I forgot to mention that the 42" tiller can be set for center and left or right offset. ***
<P ID="edit"><FONT SIZE=-1>Edited by KDL on 05/18/01 09:47 AM (server time).</FONT></P>
/ Tiller for B2410 #2
I have a B2410 with a Kuhn 50-inch (actual overall width 54 inches), and have no problem getting around with it. It does a great job, and is as wide as my tractor, and eliminates tire tracks in the tilled soil. I would have been unhappy with anything smaller.
/ Tiller for B2410 #3
Sounds like the dealer wants to sell a "slow mover"?...
Never heard of the brand, but both prices don't appear to be that enticing.
Do a search on KingKutter and check out the responses that people are saying about this value line.
Good luck.
/ Tiller for B2410 #4
Don't think I would buy a 42" tiller for a B2410. Think most folks would agree that you want a tiller at least as wide as your rear tires. The exception is of course if you get a great deal on a great tiller that has sideshift capability.
Kevin
/ Tiller for B2410 #5
Hi Again Kevin- Don't know if I got a great deal or not but I just did get the best price I could find around here on a Bush Hog RTS50 tiller, $1,550. This is a 50" tiller with offset capability and I hope it's GREAT!
For the sake of discussion though, I did want to comment about tiller size vs. tractor tire width. Like Blair's Kuhn, this tiller's outside dimension is probably about 55", the same as my outside tread measurement. But the working width is just 50" so I'm not sure how well this will cover both tracks if I leave it centered. But for me the real issue was/is... how much tiller do I need? This 50" tiller looks HUGE to my eyes and I have to remember that everytime I lower it into the ground I'll be tilling a 4'+ swath! If I was going to have a 1/2 acre or larger garden then a 5'+ tiller would seem to make more sense for me AND definetely cover both tire tracks. But our garden will probably be around 20'x40' and the other uses will be for spot leveling of ground and putting in flower beds along some fence rows. I'll probably end up replanting grass in a lot of places just because I tilled more than I needed. Time and experience with the tiller may prove me wrong but this issue comes up fairly often here (heck, some of my posts have raised this point!) and I thought taking the "narrower approach" was a better fit for my situation. It MIGHT be true for others as well.
Having said that all my other applicable implements are/will be at least 5' wide because they fit my situation better and make more sense. The only other implement I currently plan to get is a rear blade (for snow plowing) and it will be at least 6'. Fortunately I should have a few months to think about it and then I'll poll everyone about rear blades /w3tcompact/icons/smile.gif.
Till On- Dave
/ Tiller for B2410 #6
I use a 50" LandPride tiller with my B2410, and it has worked great. My rear (turf) tires measure about 55" in width, so the tiller is offset by about 5" or so to cover the RH track. The tractor would handle a 60" no problem, at least in our type of soil, but like DaveM had mentioned, I have no need for the extra capacity. I would closely check the max. sideshift on the 42" - if you will run turf tires you may not be able to get there from here.
Rob
/ Tiller for B2410 #7
there is a way to till less of a width than the tiller was built for. Just remove the tines for the width you would like to make your flower beds at. It will take a little time but works quite well and leaves a look that it's been there for a while.
/ Tiller for B2410 #8
Dave,
Not sure what size I'll end up getting. Guess my point was a little less than clear. Basically I was attempting /w3tcompact/icons/crazy.gif to say that if you get a tiller less than the width of your rear tires it is recommended that you get a sideshift so that you can cover the one side completely. I don't have my B2410 manual around but it seems to me the Max size for a tiller was recommended to be less than I had anticipated. I'm hoping to get one of the models that has a working width in the 53"-56" range to get the tire coverage. Probably going to end up with a Sovema Laser-2 140 (info at Sovema). Seem to be the most popular brand locally here among all the dealers. That way parts should be available from anyone.
Kevin
/ Tiller for B2410 #9
Art- Thanks for answering and confirming a question I posed awhile back in "Attachments" but never got a reply to! I think it was another query that sorta got lost due to the "windy" nature of my messages. Danged if I just can't always (ever?) find the right combo of words that communicate well and keeps it concise /w3tcompact/icons/smile.gif. I do try though... really!
Though it looks like removing tines has real knuckle busting potential I might just remove some after I'm sure the garden tilling is done for awhile.
Thanks Again- Dave
/ Tiller for B2410 #10
Kevin- Just so you know. I thought you were clear I just wanted to expand the topic a bit by pointing out that bigger is not necessarily better. I just couldn't remember ever hearing anyone say so! Besides with a tiller, if one can cover their right track that might work fine for lots of folks.
Take Care- Dave
/ Tiller for B2410 #11
I agree with Dave - you can make do with a tiller that isn't as wide as your tires.
I have a 36" tiller on my Kubota B6100 with an outside tire width of about 48". I can't offset my tiller.
That doesn't cause me a problem, though. In my vegetable garden, I plant in beds that are about 3' wide and there is a "walking space" between them. The tiller tills the beds and the tires run in the walking space.
When I've needed to till a larger area, I steer a slightly curved track. This makes the tiller run in the area following the outside rear wheel. By tilling from the outside in and overlapping slightly I get a nearly track-free tilled area.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
iDrive TDS-2010H...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
