Tiller Drive Shaft Sheared Off
   / Tiller Drive Shaft Sheared Off #1
Silverado21
N.A
Bought this tractor and tiller used from a dealer. First few hours of use were in packed Carolina clay but minimal to no rocks or tree roots. Heard a commotion from the gear case popped it off and found this. Not sure what to do next, don稚 know if this has a warranty, if it痴 covered, how much it would cost to replace, etc. it痴 a smartract tl-135.
   / Tiller Drive Shaft Sheared Off #2
Made in china?
   / Tiller Drive Shaft Sheared Off #5
It sure looks like there was a bit of water in that oil too.
   / Tiller Drive Shaft Sheared Off #6
Slip clutch or shear bolt?
   / Tiller Drive Shaft Sheared Off #7
You are seeing something that I'm not...
I've seen enough broken/twisted off china steel in tillers to recognize that right away though...and NO slip clutch or shear bolt will save that...
SR
   / Tiller Drive Shaft Sheared Off #8
I think a call to your dealer is in order.
   / Tiller Drive Shaft Sheared Off #10
yep, China steel is the cause!.. you just have to keep replacing it when it breaks, keep a few replacements ready so you minimize the downtime!..
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A51572)
2020 Ram ProMaster...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
197711 (A51244)
197711 (A51244)
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
