Tiller Drive Shaft Sheared Off
/ Tiller Drive Shaft Sheared Off #1
Silverado21
N.A
Bought this tractor and tiller used from a dealer. First few hours of use were in packed Carolina clay but minimal to no rocks or tree roots. Heard a commotion from the gear case popped it off and found this. Not sure what to do next, don稚 know if this has a warranty, if it痴 covered, how much it would cost to replace, etc. it痴 a smartract tl-135.
/ Tiller Drive Shaft Sheared Off #2
Made in china?
/ Tiller Drive Shaft Sheared Off #5
It sure looks like there was a bit of water in that oil too.
/ Tiller Drive Shaft Sheared Off #6
Slip clutch or shear bolt?
/ Tiller Drive Shaft Sheared Off #7
You are seeing something that I'm not...
I've seen enough broken/twisted off china steel in tillers to recognize that right away though...and NO slip clutch or shear bolt will save that...
SR
/ Tiller Drive Shaft Sheared Off #10
yep, China steel is the cause!.. you just have to keep replacing it when it breaks, keep a few replacements ready so you minimize the downtime!..
/ Tiller Drive Shaft Sheared Off #11
Yup, oil looks milky. Does the rotor part spin freely?
/ Tiller Drive Shaft Sheared Off #12
Chinese make an oil out of fish, it always looks a bit milky, i'm guessing it's used because it's cheeeep!
Fix that turd and send it down the road!!!
SR
/ Tiller Drive Shaft Sheared Off #13
SR
Right to the point.......SR as always.........:)
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2011 Ford Expedition SUV (A64557)
2011 Ford...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
