Tiller Drive Shaft Sheared Off
/ Tiller Drive Shaft Sheared Off #1
Silverado21
N.A
Bought this tractor and tiller used from a dealer. First few hours of use were in packed Carolina clay but minimal to no rocks or tree roots. Heard a commotion from the gear case popped it off and found this. Not sure what to do next, don稚 know if this has a warranty, if it痴 covered, how much it would cost to replace, etc. it痴 a smartract tl-135.
/ Tiller Drive Shaft Sheared Off #2
Made in china?
/ Tiller Drive Shaft Sheared Off #5
It sure looks like there was a bit of water in that oil too.
/ Tiller Drive Shaft Sheared Off #6
Slip clutch or shear bolt?
/ Tiller Drive Shaft Sheared Off #7
You are seeing something that I'm not...
I've seen enough broken/twisted off china steel in tillers to recognize that right away though...and NO slip clutch or shear bolt will save that...
SR
/ Tiller Drive Shaft Sheared Off #10
yep, China steel is the cause!.. you just have to keep replacing it when it breaks, keep a few replacements ready so you minimize the downtime!..
/ Tiller Drive Shaft Sheared Off #11
Yup, oil looks milky. Does the rotor part spin freely?
/ Tiller Drive Shaft Sheared Off #12
Chinese make an oil out of fish, it always looks a bit milky, i'm guessing it's used because it's cheeeep!
Fix that turd and send it down the road!!!
SR
/ Tiller Drive Shaft Sheared Off #13
SR
Right to the point.......SR as always.........:)
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
